Z1000 LTD to standard
Hard Road
Re: Z1000 LTD to standard
#136 PostAuthor: Hard Road » Sat Jan 11, 2025 1:08 am
DeadZedDave wrote:Great job ! This is how they looked back in the late 70's - no one was interested in counting the rivets back then - this one would have looked right at home outside of the pub in '78.... Hope you'll call it done now ? I always say "your bike you can do what you want" but don't spoil it - too good for that. Great transformation.....
Thanks Dave
#137 PostAuthor: Bill P » Sat Jan 11, 2025 10:05 am
Lovely bike well done :up
Hard Road
#138 PostAuthor: Hard Road » Sat Jan 11, 2025 3:41 pm
thanks guys, but i might upset a few soon !!!!!! I keep looking at it and think it'll look better with a suspension and wheels upgrade :?? I've got most of the bits just sitting their begging to be fitted and bring the bike a bit more up to date, not for the purist but its my kind of thing :D just waiting for some warmer weather to get in the shed.
baldrick
#139 PostAuthor: baldrick » Sun Jan 12, 2025 9:40 pm
they are never finished are they? :D
Hard Road
#140 PostAuthor: Hard Road » Mon Jan 13, 2025 1:27 am
baldrick wrote:they are never finished are they? :D
Nope :D
Hard Road
#141 PostAuthor: Hard Road » Fri Jan 17, 2025 3:59 pm
well its begun !!! got the rear wheel and swinger fitted, just waiting for a calliper to turn up and sort a chainguard out.
then turn the bike round and start on the front end. :D
DeadZedDave
#142 PostAuthor: DeadZedDave » Fri Jan 17, 2025 6:05 pm
All ok with me - as I always say, its your bike you can do with it what you want !
Heres one I made earlier - please excuse the 42 year old picture - thats a Suzuki GSX1100 'arm in a Mk2
A couple of questions if you don't mind ? 1) Did the GSX 'arm clear the frame footrest hanger tubes ok / without adjustment ? 2) how wide is the wheel / tyre set up - obviously my old Mk2 had a standard wheel in this pic.
Hard Road
#143 PostAuthor: Hard Road » Fri Jan 17, 2025 7:15 pm
DeadZedDave wrote:All ok with me - as I always say, its your bike you can do with it what you want !
A couple of questions if you don't mind ? 1) Did the GSX 'arm clear the frame footrest hanger tubes ok / without adjustment ? 2) how wide is the wheel / tyre set up - obviously my old Mk2 had a standard wheel in this pic.IMG_0499.jpeg
Cheers Dave, no the very end of the footrest hangers where the twin exhaust silencers bolt to got in the way, so hacked them off !!!!! but as ive gone 4 into 1 i can use the right footrest bolt to hold the end can. doesn't bother me about cutting them off but will keep em just in case.
the wheel is a 4.5 inch bandit wheel with a 160 tyre, it come off my GSX1100ET as ive fitted a 5,5 inch wheel on it with a 180 tyre. :D
DeadZedDave
#144 PostAuthor: DeadZedDave » Fri Jan 17, 2025 9:52 pm
Thanks for the info - useful to know ! Keep the updates coming ....
Hard Road
#145 PostAuthor: Hard Road » Fri Jan 17, 2025 11:00 pm
DeadZedDave wrote:Thanks for the info - useful to know ! Keep the updates coming ....
no probs Dave. will do. :wink:
Andy M
#146 PostAuthor: Andy M » Sat Jan 18, 2025 1:30 pm
How is the chain alignment with the Bandit arm in ?
Hard Road
#147 PostAuthor: Hard Road » Sat Jan 18, 2025 5:25 pm
Andy M wrote:How is the chain alignment with the Bandit arm in ?
its not a bandit swinger its off my GSX1100, (B12 swinger is in the GSX) the chain is dead straight as ive used a 3/8 offset front sprocket. :wink:
#148 PostAuthor: Z1streetfighter71 » Sat Jan 18, 2025 6:45 pm
Wow... came to the thread to congratulate you on a sterling finish build and here we are off on another journey. So iv done this same conversion start to finish on a z1000 and funny enough will be moving the complete front and back end from my 77 to my 78. Most important question is what front end will you be using to match up with the rear? I presume you used a bandit or gsxr750 rear wheel?
Hard Road
#149 PostAuthor: Hard Road » Sat Jan 18, 2025 8:51 pm
Z1streetfighter71 wrote:Wow... came to the thread to congratulate you on a sterling finish build and here we are off on another journey. So iv done this same conversion start to finish on a z1000 and funny enough will be moving the complete front and back end from my 77 to my 78. Most important question is what front end will you be using to match up with the rear? I presume you used a bandit or gsxr750 rear wheel?
I just can't help myself :?? I intended to have a pretty much standard Z1000 BUT...... after looking at it for some time i just couldn't deal with the skinny wheels, especially when its parked next to my GSX1100 with wide wheels on.
yeah the rear wheel is a bandit and the front will be too.
I have a complete bandit front end but I know i'll have lock to lock issues, can't deal with a small amount of lock.
so i have a set of yokes off a Vstrom, they fit the 43mm forks and also have more offset so hopefully have a decent lock. If its not enough then maybe pull the tank back a few mm.
Andy M
#150 PostAuthor: Andy M » Sat Jan 18, 2025 9:48 pm
I built this last year , used Bandit front and back and obviously engine , the steering lock issue I got over with a set of billet yokes . I didn't search for another alternative at the time. I am considering going back to a Z engine , just looking into the speedo issue etc as its a later front end .
