Gpz1100a1 resto mod
stusco
Gpz1100a1 resto mod
#1 PostAuthor: stusco » Sat Nov 08, 2025 11:28 am
Got the chain lined up
And amazingly the chain slider fits without needing altered
Re: Gpz1100a1 resto mod
#2 PostAuthor: deka » Mon Nov 10, 2025 9:45 am
we need to see more of this as it looks like you have already started very interested to see what you are up to
#3 PostAuthor: Z1streetfighter71 » Tue Nov 11, 2025 2:08 pm
Bandit 1200 swingarm?
stusco
#4 PostAuthor: stusco » Tue Nov 11, 2025 4:10 pm
Gsxr600 with a zrx1200wheel
#5 PostAuthor: Z1streetfighter71 » Wed Nov 12, 2025 2:54 am
stusco wrote:Gsxr600 with a zrx1200wheel
Nice! interested to see how this will turn out mate cause I’m gonna be doing the same thing next spring.
stusco
#6 PostAuthor: stusco » Sun Dec 14, 2025 11:28 am
Next problem , im trying to find some rearsets to fit the gpz ? Im don’t want to cut or weld the frame bracket so i can fit the standard ones if i cant handle the rearsets
#7 PostAuthor: Z1streetfighter71 » Sun Dec 14, 2025 12:02 pm
It would probably be less hassle to have an adapter plate made so you can choose what ones suit you.
#8 PostAuthor: Al » Sun Dec 14, 2025 2:28 pm
stusco
#9 PostAuthor: stusco » Sun Dec 14, 2025 2:35 pm
Thanks for looking , unfortunately they are not what im looking for.
DeadZedDave
#10 PostAuthor: DeadZedDave » Mon Dec 15, 2025 10:11 am
If you can give us a clue what you are looking for then maybe someone can help !
Those rearsets AL has posted look pretty much what you get with aftermarket stuff.
It'll be good to see what you finally come up with.
stusco
#11 PostAuthor: stusco » Mon Dec 15, 2025 6:39 pm
Something like these
Sifu
#12 PostAuthor: Sifu » Tue Dec 30, 2025 4:01 am
That’s very nice
stusco
#13 PostAuthor: stusco » Fri Jan 16, 2026 3:56 pm
Getting ready to close up the bottom end, I’ve got to get the fastners plated first so im going through them and find these 2 m8x80 i think they are for crank support what is the wasted part for (where do these go?)
DeadZedDave
#14 PostAuthor: DeadZedDave » Wed Jan 21, 2026 10:34 am
If my memory is correct, the 2pcs. M8x81mm bolts go in the lower crank case on the ignition side - first pair inboard of the ignition housing mounting face. The "wasted" design is used widely in engineering and often seen in automotive application. Type "Wasted Bolt Design" into your search engine and you can read all about it. Suffice to say its for engineering reasons.
