Pigfords OLD effort......now JULES NEW PROJECT!!!!!
#241 PostAuthor: Ginger Bear » Sat May 09, 2009 7:07 pm
Cool Pigster, walk away n' leave for a while, then come back & find what wasn't the obvious. Well done, another bit of inspiration. :D
#242 PostAuthor: Pigford » Sat May 09, 2009 8:21 pm
Cheers GB....... I had planned to do it anyhow... just couldn't be arsed - and had to read up about it & get me head around it before I tried me hand :shock:
I had set the cams as they were before I stripped it down... so whoever did it was not too hot :roll: The bike had only been attended to by local bike shops to the previous owner, as he new diddly squat about mechanics :|
If the bike STILL has running problems... I'll be breaking the b******d :evil:
#243 PostAuthor: paul doran » Sat May 09, 2009 9:54 pm
zeroed wrote:looks very technical, you sure your not a doctor :cheek
Pigford a Doctor :lol: :lol: :lol:
yeah a fcuking witch doctor
#244 PostAuthor: Al » Sun May 10, 2009 10:04 am
Good news Mark. Glad you found out what the others didnt know or couldnt work out for themselves. Is it the reason he sold the bike. Got it fixed.... mechanic swears blind its right..... owner not satisfied....etc etc.
Get the quicky gas on it and well go and kick some tripple botty at the Pod!
Mines going now and when Fatty Z1R gets his bits he'll be up and running too.
Barry should be below the magic 9.5 by now so a bit of catching up to do.
P.S. Ive got one of those degree disks from Wassell. Like all thir other stuff it was sub standard. Sure mines only got 359 degrees on it!!
Zeroed; did you edit your post or it it something more sinister????
Part of the text disappeared whilst i was reading it!!
zeroed
#245 PostAuthor: zeroed » Sun May 10, 2009 10:26 am
zorded - Zeroed; did you edit your post or it it something more sinister????
edited and deleted a question few mins after a posted
no hoodoo voodoo here
Taffus
#246 PostAuthor: Taffus » Sun May 10, 2009 10:55 am
just bouguht a degree wheel from debbens, just plucking up courage to remove the head from my GPz.......first time for me on a dohc engine.........
#247 PostAuthor: Pigford » Sun May 10, 2009 11:00 am
Taffus..... Loads of photo's & take your time....... Check & re-check :wink:
Thats why I left this bike for so long... wanted to make sure my head was clear..... :?? and have plenty of time to tackle it again :twisted:
I've never degreed cams before and hopefully I'll have a good result when I fire it up in a week or two :shock:
Post loads of details/photo's in the Project scetion too :!: and include which biscuits you prefer when "spanner-spinning" :wink:
Taffus
#248 PostAuthor: Taffus » Sun May 10, 2009 11:05 am
How did you mount your dial gauge?
#249 PostAuthor: Pigford » Sun May 10, 2009 11:08 am
.....Blue tack........ :shock:
Taffus
#250 PostAuthor: Taffus » Sun May 10, 2009 11:09 am
still waiting for my dead stop from debbens, hows does a dead stop work?
#251 PostAuthor: Pigford » Sun May 10, 2009 11:11 am
But that didn't work to well :lol:
I used the clamp off a proper dial stand, and the bit that clamped onto the rod fitted on the cam cap allen bolt head :wink:
With a bit of jiggling & luck, it was in the right position :twisted:
All thats needed is to get a bit of bucket deflection ( valve open about 1mm) to take the degree readings. Then you can calculate the lobe centres.... aiming for 108 degs in my case. This should be a good average starting point for these lumpy cams :|
#252 PostAuthor: Pigford » Sun May 10, 2009 11:18 am
Again I modified the dial gauge adaptor (14mm) which screws into the plug hole. Anything that is a positive stop for the piston ( a few mm from TDC) is OK. Just wind the engine over by hand (the 17mm nut on ignition side) until the piston touched it.
Set degree wheel to a few degrees before TDC. Fix a pointer off a casing screw somewhere handy :!:
Next reverse engine nearly a whole rev until the piston touches the stop again. Note the degree reading. It'll be X degs BTDC. Divide the diference by 2 and this will be where you set the degree wheel when the stop is removed, at TDC. Re do the check with the stop & the pointer should be an equal amount either side of TDC if right :!:
#253 PostAuthor: Al » Sun May 10, 2009 7:01 pm
http://www.oldkawman.com/okndrebuild.html
Heres' a slightly fuller explanation Taffus with a couple of identical pictures to Piggys'
What is the reason for taking the head off? Is something not right under there.
#254 PostAuthor: Al » Sun May 10, 2009 7:05 pm
no its here; http://www.youtube.com/watch?v=BKXKWBcaV3A
thought that the site was compromised!
Taffus
#255 PostAuthor: Taffus » Mon May 11, 2009 8:34 am
zorded wrote:http://www.oldkawman.com/okndrebuild.html
bike is a converted B1 so the inlet tracts are longer than standard which is preventing me from putting a standard airbox on, also I suspect the valve seals are gone.
I have another head from Pigford which has been gas flowed and has shims under buckets.
bike is an Italian import and alleges it has done only 20K miles but it does use a lot of oil.
huge flat spot at 5k, just made worse this weekend by lowering the needle (will back out that mod tonight!) hence wanting an airbox.
