Happy days!
Spotted these cams on ebay at DK spares.
Listed only as "Z900 CWC high lift cams with some water marking and might need a regrind".
They looked ok to me on the pic's and maybe not too wild so took a cheeky throw away punt at the £29.99 starting bid expecting not to win .
Well! To my suprise no bugger else bid (probably due to the iffy description) and i won 'em
They turned up this morning and result.
Norris .407 lift fast road cams in near perfect nick, an absolute bargain .
Couldn't have asked for a better cam to go with the engine and carb mods so once the exhaust is finished it's out with the std jobbies and in with these.
Yippee!
Yippee!
Very very good thread, amazing what you can do. Wish I had your talents. Keep it coming. Love the Zed.
cams
I looked at those but there was no info so I didn't both, you've had a right result there. Very similar to Andrews 3X cams, a good size cam and you can still run shim on top. Buzzard.
Every man should have a shed (for bikes obviously..)
Re: cams
buzzard wrote:I looked at those but there was no info so I didn't both, you've had a right result there. Very similar to Andrews 3X cams, a good size cam and you can still run shim on top. Buzzard.
Yes! Can't believe DK didn't put a better description.
They clearly have 'Norris Cycle .407' engraved on them.
Not much progress as have been busy with other things but have had time to fashion a low profile oil filter cover.
Std cover on left and a slimmed down one on the right.
Center has been recessed to take an 'O'ring and the head of the bolt.
I machined the chewed head off a spare filter bolt and turned up a flush style one which was pressed on to the now stepped shaft of the old bolt.
A hole was drilled in the end and a hex recess broached in to take an allen key.
I sweated some sifbronze around the join to be 100% oil tight (not really needed) which was then machined flush and also ran some over the head and faced it off to leave a rust resistant finish.
In situ. Sorry for the blurry pic but you get the idea.
- big green bus
- Flying Tiger
Hope you have a speedy recovery and get lots of rest mate
Flying Tiger Paintwork - www.facebook.com/FlyingTigerPaintwork - flyingtigerpaintwork@hotmail.co.uk - 07796693751
Crofty wrote:Take it easy for a while Rob, get your feet up
Easier said than done.
I've already been out on the Zed on a day trip to a rally last week and plan on camping at the squires meet next month even though i'm not supposed to even ride a treader for three months.
Driving me crazy sat about doing nowt, if I had any hair i'd have torn it out by now
Users browsing this forum: No registered users and 124 guests
