Z650 build, mix of Zephyr, GPZ and B3 650.
Posted: Sat Oct 11, 2014 9:43 pm
Been on with this since September, so ignore the what I did today bits, i might of done it weeks ago.
Have been collecting parts for a while to build a spare/new motor for me 650. Just got the casings and covers back from vapour blasting and giving them a good clean to be sure no media left in the oilways and threads.
Its going to be Z650 crankcases and gearbox, GPZ750A1 crank, rods, barrels, pistons and cams and a Zephyr750 head ( I like the look of the Zephyr head as it is like the 900 with rounded cam cover and has more fins for better cooling.
Note extra space at end of cams, much more metal in the Zeph heads.
Will need to round the corners of the barrels with a file to match Zephyr head.
Came to start putting the cases together and made a faux pas in the choice of cases. I had early 650 ones which did not have the slots to locate the cam chain tensioner blades. Doh.
Anyway I was going to do a std 650 rebuild on an early engine, so these are going under the table and have just purchased a reconditioned head from Dave Bones.
So,I found a cheap F2 engine, prefer these cases to later 750 as they have the correct spacing of engine mounts to fit straight in any 650 frame and added benefit of no need to bore the throats to accept 750 liners and had them vapour blasted.
Before taking them to be cleaned, I bought new shells and checked with Plastiguage and they are all OK. This time I used the stampings on the crank and crankcases, all good. Previously I have had the internal bores on the cases measured and the crank micrometered up.
I also scored a new old stock primary drive chain at less than half price, new cam chain and oil seal set.
When rebuilding the 650 /750 motor I like to treat it as 4 stages.
First stage. Get cases together, replacing any items critical to good running, bearings and chains, plus crank 'o' rings, gearbox parts etc
Second stage. Insert fully rebuilt starter clutch, new ZR7 oil pump then sump on replacing the 'o' rings and oil filter as well.
Third stage. Barrels and head on, new pistons and rings in this engine, rebuilt head also.
Fourth stage. Bang all side components on, restored clutch basket, new clutch plates, ignition, alternator rotor, output shaft cover.
While I was looking for the primary chain, I had Plastiguaged the crank and rods and assembled using the existing bearings as they were unmarked and within tolerance, only putting new mains in on this one
Picture shows one of the ports that let the oil pump feed the transmission shaft bearings with oil.
Need to make sure these are not clogged with blasting media before assembling.
