Z1a Restoration
Z1a Restoration
I did say that I would start this thread at the weekend so here goes.
Never done a restoration before so lots of questions will be asked i'm sure
The intention is to strip down and paint frame and the original swinging arm and then rebuild using as much of the original parts as possible, even if not 100% good, also paint tank and panels.
Anyway I have started -
Will keep you posted as time goes on
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Z1a Restoration
Already have a couple of questions but I will post in the appropriate place
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Original Z1 Swing arm has arrived from Ohio,US.
Quick fit up just to prove out all is well before continuing strip down.
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
First bit of advise.............buy an hydraulic bench
Re: Z1a Restoration
Advice taken,
Hydraulic something
Cracking on......
Hydraulic something
Cracking on......
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
- 8 Valve Mark
Re: Z1a Restoration
looks like a cracking basis for a summer resto
good luck cas
good luck cas
Re: Z1a Restoration
Coming on,
Had to stop for today though,
Must have been the penetrating fluid making me feel dizzy
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Bracket made and welded.
Next for Paint and Chrome
The Drawing PDF that I put together is attached should anyone require one.
- Attachments
- Damper Bracket.pdf
- (143.37 KiB) Downloaded 237 times
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Quick update -
Powder Coating back
CJ Ward Stove Enamelling,
Sutton.
2 Weeks
Chrome Back -
Classics And Chrome,
Hinckley
2 Weeks
Clocks Back -
Al Marshal
Lovely Job
Powder Coating back
Sutton.
2 Weeks
Chrome Back -
Hinckley
2 Weeks
Clocks Back -
Al Marshal
Lovely Job
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Ball Burnishing back today.
Sutton Soda Blasting
1 week.
Great natural finish
Probably not for bling lovers.
1 week.
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
BigZCas
Nice to see the bitz come back with no bling on as per the factory finish but then again the frame came out with a blow of black paint and not powder coat.
I prefer to see a painted frame and associated bitz.
Regards
Steve
Regards
Steve
Re: Z1a Restoration
wilsonsjw11 wrote:I prefer to see a painted frame and associated bitz.
I've got a '77 z1000a to do (after I've tidied up my z900) and I'm fancying painting the frame myself. What would you (or anyone else) recommend to get a decent durable finish that's close to factory?
Oh and nice job you;re doing there BigCas..
Re: Z1a Restoration
Paint came back today.
Lovely job From Trig, Coalville.
Plating also back.
Build started
Plating also back.
Build started
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Now for the fun part!! Enjoy!
Re: Z1a Restoration
Powder coating finishes won't please everyone but the finishes available now are pretty close.
Frost Extreme Chassis Black has been used by at least one member in the past with good results.
http://www.frost.co.uk/frost-frame-chas ... easer.html
Great job Steve
