zir tc project
Fred the Zed
Re: zir tc project
#16 PostAuthor: Fred the Zed » Tue Jan 23, 2018 8:17 am
Pigford wrote:Now his looks rather interestink :hot
:pop :pop :pop :pop :pop :pop
You know it makes sense. Offset some of the cost by dispensing with the carbs and exhaust.....
Paid Up Member
hotrod
Re: zir tc project
#17 PostAuthor: hotrod » Thu Mar 22, 2018 9:58 pm
more pics of the turbo build
Gonzo
Re: zir tc project
#18 PostAuthor: Gonzo » Thu Mar 22, 2018 10:59 pm
I like your swingarm... who makes it and what's the max tyre width it can take?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Re: zir tc project
#19 PostAuthor: ZedHead » Fri Mar 23, 2018 11:03 am
Gonzo wrote:I like your swingarm... who makes it and what's the max tyre width it can take?
https://www.saisei-europe.com/Shop/Prod ... rm-type-11
saltflatracer
Re: zir tc project
#20 PostAuthor: saltflatracer » Fri Mar 23, 2018 9:08 pm
what size is the motor 1327? see you are using a MTC big block
hotrod
Re: zir tc project
#21 PostAuthor: hotrod » Fri Mar 23, 2018 9:48 pm
its a 1260 with low comp pistons ,liners are quite thick so the bores will be stable ,plus loads of room for re bores when it goes bang
hotrod
Re: zir tc project
#22 PostAuthor: hotrod » Fri Mar 23, 2018 9:50 pm
it is a pmc job ive got a 4.5 rim with a 160 tyre but there is room for a wider set up
Re: zir tc project
#23 PostAuthor: ZedHead » Sat Mar 24, 2018 8:17 am
It will take a 170 tyre.
Brilliant project BTW :D
Reecy
Re: zir tc project
#24 PostAuthor: Reecy » Sat Mar 24, 2018 11:44 am
Love that swing arm
Coose
Re: zir tc project
#25 PostAuthor: Coose » Sat Mar 24, 2018 12:29 pm
:pop
saltflatracer
Re: zir tc project
#26 PostAuthor: saltflatracer » Sat Mar 24, 2018 7:13 pm
Nice build Hotrod, sensible size 1260cc as you say nice & stable with loads for rebores if necessary.
What size valves has the head got in it & who done the porting?
hotrod
Re: zir tc project
#27 PostAuthor: hotrod » Thu Mar 29, 2018 6:45 pm
saltflatracer wrote:Nice build Hotrod, sensible size 1260cc as you say nice & stable with loads for rebores if necessary.
the valves are the std size ive done all my own engine work its had the ports cleaned up but not ported ,
Zomerset Zed
Re: zir tc project
#28 PostAuthor: Zomerset Zed » Sat Mar 31, 2018 8:55 pm
Drool...... :pop
Big Fluff
Re: zir tc project
#29 PostAuthor: Big Fluff » Tue Apr 10, 2018 3:00 pm
Just be sure to fit boost activated retard if you plan to go over 5 psi.
If you don't, then as you say you WILL be reboring it on a regular basis!
You'll also need at least one additional crankcase breather.
Nice project though.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
Simonic
Re: zir tc project
#30 PostAuthor: Simonic » Tue Nov 27, 2018 3:53 am
I wonder how this one is progressing.....
'83 ZX1100 '81 Z1000ST, '04 GSX1400, '19 Dodge Challenger Hemi
