Page 2 of 3
Re: zir tc project
Posted: Tue Jan 23, 2018 8:17 am
Author: Fred the Zed
Pigford wrote:Now his looks rather interestink :hot
:pop :pop :pop :pop :pop :pop
You know it makes sense. Offset some of the cost by dispensing with the carbs and exhaust.....
Re: zir tc project
Posted: Thu Mar 22, 2018 9:58 pm
Author: hotrod
more pics of the turbo build
Re: zir tc project
Posted: Thu Mar 22, 2018 10:59 pm
Author: Gonzo
I like your swingarm... who makes it and what's the max tyre width it can take?
Re: zir tc project
Posted: Fri Mar 23, 2018 11:03 am
Author: ZedHead
Gonzo wrote:I like your swingarm... who makes it and what's the max tyre width it can take?
https://www.saisei-europe.com/Shop/Prod ... rm-type-11
Re: zir tc project
Posted: Fri Mar 23, 2018 9:08 pm
Author: saltflatracer
what size is the motor 1327? see you are using a MTC big block
Re: zir tc project
Posted: Fri Mar 23, 2018 9:48 pm
Author: hotrod
its a 1260 with low comp pistons ,liners are quite thick so the bores will be stable ,plus loads of room for re bores when it goes bang
Re: zir tc project
Posted: Fri Mar 23, 2018 9:50 pm
Author: hotrod
it is a pmc job ive got a 4.5 rim with a 160 tyre but there is room for a wider set up
Re: zir tc project
Posted: Sat Mar 24, 2018 8:17 am
Author: ZedHead
It will take a 170 tyre.
Brilliant project BTW :D
Re: zir tc project
Posted: Sat Mar 24, 2018 11:44 am
Author: Reecy
Love that swing arm
Re: zir tc project
Posted: Sat Mar 24, 2018 12:29 pm
Author: Coose
:pop
Re: zir tc project
Posted: Sat Mar 24, 2018 7:13 pm
Nice build Hotrod, sensible size 1260cc as you say nice & stable with loads for rebores if necessary.
What size valves has the head got in it & who done the porting?
Re: zir tc project
Posted: Thu Mar 29, 2018 6:45 pm
Author: hotrod
saltflatracer wrote:Nice build Hotrod, sensible size 1260cc as you say nice & stable with loads for rebores if necessary.
the valves are the std size ive done all my own engine work its had the ports cleaned up but not ported ,
Re: zir tc project
Posted: Sat Mar 31, 2018 8:55 pm
Author: Zomerset Zed
Drool...... :pop
Re: zir tc project
Posted: Tue Apr 10, 2018 3:00 pm
Author: Big Fluff
Just be sure to fit boost activated retard if you plan to go over 5 psi.
If you don't, then as you say you WILL be reboring it on a regular basis!
You'll also need at least one additional crankcase breather.
Nice project though.
Re: zir tc project
Posted: Tue Nov 27, 2018 3:53 am
Author: Simonic
I wonder how this one is progressing.....
