Z 1000 St E2
Re: Z 1000 St E2
The carbs have been completely rebuilt and the intake rubbers are pattern parts. What is happening is that after the throttle is blipped it takes a while to return to tick over. But once it is at tick-over it idles quite nicely, i sealed the carb rubber to cylinder head with silicon. The carburetors i believe are off a kz1000 b4 having x 2 fuel inlets instead of one.
Re: Z 1000 St E2
Today i attempted to tidy up the wiring, with mixed results.
I am trying to get the routing right to give it a semblance of order.
After this i will attempt to get it MOTed
Re: Z 1000 St E2
i need to find the frame number for the mot
I have scraped some of the powder coat off the steering head, But only found the made in japan stamp, Does any one know where the frame number are?
Re: Z 1000 St E2
Hi
the frame number is on the left hand side of the steering head, close to the "made in japan" stamp.
That's the reason why I don't like powder coating, it's too thick...
Good luck with the search.
Re: Z 1000 St E2
Setting off for mot first time in 18 years
Waiting for mot
Failed mot on leaking fork seal and no passenger foot rest
Waiting for mot
Re: Z 1000 St E2
This is the offending fork seal. caused by a pitted stanchion.
Fork stripped ready for new stanchion and seal.
Re: Z 1000 St E2
Hi Avon
don't let a little set back get you down, replace both the fork oil seals and put some passenger footrests on your bike, these are only minor problems, no big difficulties with huge amounts of costs and work.
Go for it! You can fix it.
During the time I was writing a reply, you allmost fixed the little problem! Good to see that you allso put a new stanchion in it. Once the chrome is damaged it's useless to place new seals, they get damaged after a few miles and the work you did is lost. The rubbing of the sharp edges causes damage to the seal.
When the chrome is damaged above the normal working range of the stanchion there is no problem.
Re: Z 1000 St E2
Avon,
Another old beauty saved. Well done.
Re: Z 1000 St E2
New fork stanchion and seal fitted
Parts all fitted
Parts all fitted
Re: Z 1000 St E2
Ready for mot retest
Passed mot happy mot inspector
Re: Z 1000 St E2
After i came back from mot the rear brake disc was very hot
I backed off the push rod
Small leak off fuel tap bolt
Re: Z 1000 St E2
Nice to see other ST back on the road.
Steve.
Steve.
Re: Z 1000 St E2
Relatively painless after so long... all you need now is a few runs out
Re: Z 1000 St E2
First run out coverd 50 miles
alast problem with back brake to much play on brake pedal
Re: Z 1000 St E2
During the run out there was a problem with the back brake there to much play on the brake pedal
Users browsing this forum: No registered users and 90 guests
