Re: Z1B Restoration
Posted: Sat Nov 17, 2018 3:34 pm
Hi men
did some more "work" on the bike last week.
I assembled the handlebar switches.
They were painted satin black a few months ago and yesterday I painted the lettering on them.
White and yellow as they were originally.
I keep the little parts from inside the switches in a little container for making ice cubes, it's small, it has a lot of seperate boxes and a lid to close in order to keep the parts where they must stay.
As you can see the two wires that run from the killswitch were cut in order to free the kill switch from the casing.
Those older switches have the wires soldered on the switch, the newer switches have two little screws.
I soldered them together and insulated the wires with shrinking tube.
Don't forget to run the wires through the holes in the upper casing before reconnecting them!
After that it was time to reassemble the killswitch.
There are some little parts in the switch: 3 springs, a V shaped copper plate and a tiny steel ball.
Don't loose them! Put everything at the correct position and close the switch with a C shaped circlip.
Try to do this when you're calm and when your hands don't shake!
The upper casing is reassembled, now it's time for the lower casing.
There are 2 switches in the lower casing, the starter button and the light switch.
Start with the starter button. Put the black button in place, take the spring and the insulator plate with the wires and put those in the correct place (mind the place of the wires!) There are raised lines inside the casing where these parts must come.
After they're in the correct position, put the little metal plate above them in order to keep them in place and secure it with a little screw.
Then it's time to install the light switch. Hopefully the little brown plate didn't crack on your switch. I had to replace it, a precision job! The three wires may not touch eachother.
I have a lot of spare parts from older switches, if you have old switches, don't throw them away! Disassemble them and keep the parts for spares.
Again make sure that the switch is in the correct position
After that it's time to install the little handle.
You've noticed that there are a lot of little metal plates with different shapes and sizes. They all have a specific place inside the casing and a specific purpose. You allso have to put them in the correct way. These plates hold the switches and the wires in place.
When the interior switches are in place, it's time to secure the loom in the casing.
If the black plastic hose is undamaged, I use it, if it's damaged I replace it but that's another story!
Make sure that the black hose is inside the casing and secure the loom with the metal plate and screw.
Last but not least the black plastic hose is cleaned, there's allways a lot of dirt and grease on it. Clean it and "feed" it with some tire spray. It becomes shiny like new.
That' all for the right hand switch.
I can do the same for the left hand switch but that might be a little boring.
If you want the pictures of that reassembly, just give me a shout!
