Here's my 1100b1
This is how I got it after a long time looking ....
And now so far ..
Just stripping and mocking up
Spec.
Std engine
Gsxr flat slides
Zx9r f model forks love the 46mm forks.
Zrx 1100 rear end inc shocks
More pics next week
Gpz1100b1 ....
Re: Gpz1100b1 ....
Hi MrC
please make her beautifull again, don't change her too much. I can see a lot of parts have been changed allready. Is it really impossible to get her back to standard? It seems to me that you don't want that.
If you're gonna change her, please end up with a nice riding bike, don't abandon your project and please don't do anything irreversible. There are allready too many unfinished projects in sheds all over Europe.
I wish you all the best with your project and I will follow your progress!
Re: Gpz1100b1 ....
Philippe wrote:Hi MrC
Thanks I have no intention of changing anything so that the original parts cant be re fitted and they are staying with the bike . The only exception to this is the rear shock mounts which I'm having custom made and I will have to cut the old ones off but sympatheticily .my zx9r E forks have had the stem machined to take std size gpz bearings . I'll post more pics ..later ..
Re: Gpz1100b1 ....
Hi MrC
if the original shock mounts are not wide enough to fit a larger swing arm, there are other solutions! Take a look at the other topics where changes to bikes are made, there are extentions available to mount on the original shock mounts.
Re: Gpz1100b1 ....
Stripped and off to powder coating today with the zrx arm ..
Re: Gpz1100b1 ....
Slight progress head stock machined and swing arm and wheels mocked up for fit ..
Re: Gpz1100b1 ....
Rear shock extenstended mounts collected . Hopefully done so they look stock and bolt in as apposed fo weld in a little machining and back to std .
Re: Gpz1100b1 ....
I like what you have done so far MrC !
If you don't mind me asking, who made the rear shock mount adapters?
