So why scan the chain cover?
Well the old Z wasn't completely original. Harris 4 into 1, no centre stand or air box and a few other odds n sods missing.
So rather than get it back to original I decided to make a few modifications, because the forks and wheels and brakes are a bit dated.
I'd already got a Suzuki GSXR USD front end I'd picked up a while back for the purpose of uprating the Zed and I'm thinking what about the rear end. May be GSXR or R1 would give better braking and suspension with a nice fat back tyre.
I'm searching eBay and not seeing anything that takes my fancy, then out of the blue, from where I know not, I think “Hayabusa”.
There was loads of 'busa stuff out there. Pretty soon I'd got all the rear end. Wheel, Swing arm, shocker and linkage, brake calliper the lot.
Trouble is the 190 nice fat back tyre gets in the way of where the chain is. I measured the old and new and worked out the drive sprocket needed moving out 27mm to clear the tyre. This presented a new problem. I knew the Busa arm wouldn’t go straight into the Z frame without some modification, but the new line for the chain meant the frame was in the way too. Hmmm!
As it happens the Z1 frame narrows just past the bottom engine mounting, which I'
m sure you all know. If it were straight, I reckoned, everything would be good. There was only one thing for it. Get the grinder out and cut the middle out the frame. Luckily I’d built a frame jig about 30 years ago that is ideal for making motorcycle frames. It was just lying there and I thought I would be a damn shame not to use it again.
