S&S Silver Saxon #8
RAYZ1
Re: S&S Silver Saxon #8
#76 PostAuthor: RAYZ1 » Thu Feb 20, 2020 12:18 am
GuyHughes wrote:
RAYZ1 wrote:I think I do hate doing switch gear ...virtually every screw seized , alloy eaten by brake fluid crystallisation
Whats the black paint you are using for the switch gear? I have some to do and want to get the right stuff, (not high gloss).
Hi Gary, I use Simonize tough black satin finish , use it on the engine as well
Ray
RAYZ1
#77 PostAuthor: RAYZ1 » Thu Feb 20, 2020 12:22 am
Carb here , its certalny big enough , Big Fluff has given me setting for fuel valve, jets etc. - Thanks Will
cable sheaths are to long , .. would it be possible to cut the sheath back at the other end to reveal more cable .. I will try on an old cable
GuyHughes
#78 PostAuthor: GuyHughes » Thu Feb 20, 2020 9:09 am
Ray
Guy
Big Fluff
#79 PostAuthor: Big Fluff » Sat Feb 22, 2020 9:11 am
I like the little plaque to cover the frame mod, very nice.
Looking at the throttle cables Ray, I don't think the adjusters will go in the guide tubes on the HSR. When I make cables for bikes with a HSR, I put the adjuster about 2/3rds along the new cables and just a standard outer end ferrul to go into the guide tubes.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
wilsonsjw11
#80 PostAuthor: wilsonsjw11 » Sat Feb 22, 2020 7:19 pm
Ray,
Great posts and excellent photo's of a very good restoration.
All the best for the commissioning.
Regards
Steve
RAYZ1
#81 PostAuthor: RAYZ1 » Sun Feb 23, 2020 9:39 pm
Thanks Steve ,
fired her up today and had her idling away and revving sounding great, the spitfire must have given her some luck , not taking it much above 4k rpm , as havent even set the ignition timing properly yet , so thats was really great other than the chrome on the header blistered to hell in less than a minute - had a bit of a read up , copper base will do this and all show chromers love copper , so it will be nickel or ceramic - but will do that once everything set up and ironed out , may just go turbo x black ceramic from cam coat
the blistering is a cosmetic thing , if it wouldnt start or had a calamity it be up for sale cheap!
Big Fluff
#82 PostAuthor: Big Fluff » Mon Feb 24, 2020 9:47 am
That's a real shame about the blistering chrome Ray... that's why I always double nickel plate all the turbo pipework, as on the prototype. Even when it goes blue, you can simply polish it back to bright nickel no problem. Better than ceramic I think personally.
RAYZ1
#83 PostAuthor: RAYZ1 » Mon Feb 24, 2020 11:53 pm
Big Fluff wrote:That's a real shame about the blistering chrome Ray... that's why I always double nickel plate all the turbo pipework, as on the prototype. Even when it goes blue, you can simply polish it back to bright nickel no problem. Better than ceramic I think personally.
I know I just love the look of chrome header with blue , they will have it tomorrow by 1pm and I’ve asked for it back before 1 week
Friday , it took about 4mins to come off so there was no point in liking at it , away to fit up brakes , once brakes are done and exhaust done it’s bodywork.
PS the chromers actually said sometimes copper does that on really hot exhausts - I think it’s called out gassing , why on earth they did copper when they knew it was turbo gear ..
RAYZ1
#84 PostAuthor: RAYZ1 » Thu Feb 27, 2020 7:34 pm
Crap stuff tuned into shiny stuff in the shed , it’s s dirty job
RAYZ1
#85 PostAuthor: RAYZ1 » Sat Feb 29, 2020 8:17 pm
Yip rickman shift and brake levers are a complete pain to strip , unseize and restore probably about 15 hrs work in that lot
Big Fluff
#86 PostAuthor: Big Fluff » Sun Mar 01, 2020 8:39 am
Simply stunning!
davejames
#87 PostAuthor: davejames » Sun Mar 01, 2020 9:05 am
Fantastic work, another one being brought back to better than new :D
RAYZ1
#88 PostAuthor: RAYZ1 » Sun Mar 01, 2020 10:25 pm
Thanks for the votes guys it can get a bit tiring dealing with rust and shit but near the end ... I hope , tidy up bodywork next after Big Fluff sets here up like a switch watch on Saturday ! ( hope the header is back!)
RAYZ1
#89 PostAuthor: RAYZ1 » Sun Mar 08, 2020 1:00 am
Thanks to Big Fluff - Saxon running beautiful today rechromed header not blistering , getting some nice blue and yellows with the heat
Well done Will B
Big Fluff
#90 PostAuthor: Big Fluff » Mon Mar 09, 2020 4:53 pm
Ray - It was an absolute pleasure to get No.8 up and running and also to see the "old girl" again (prototype I owned for many years).
Thank you so much for your overwhelming hospitality over the weekend, laughter and friendship, a brilliant weekend indeed, made only sweeter by the accompanied purchases.
See you soon and hope you can do something with the front mudguard on your course.
Will
Users browsing this forum: No registered users and 119 guests
