Z900ltd Resto
Z900ltd Resto
As the 650 is up and running now ive started on the 900 Limited i,it won't be one for the purists as its gonna
be a poor mans Z1 in colours to match my z900rs , i know some people will be yawning now but fancied doing
one different to normal for my self ,couple pictures hopefully to follow , i think it was the scruffiest engine
ive had the pleasure to own
Re: Z900ltd Resto
The frame is back from powdercoaters now and a Gentleman on here set me up with some
alloys for it to get rid of 16" back wheel so let the fun begin
Re: Z900ltd Resto
Hi Bill
this looks very promising,I'm looking forward to see the progress!
Good luck with the build. Keep the pictures coming!
Re: Z900ltd Resto
Cheers Philippe
frames back now in satin black like the Z650 my latest favourite i guess the engine is on its
way back together and started to clean check wiring harness etc which appears in really good
order, my h2a has just had a rear end refresh swing arm bushs etc
time to do some riding now summers here though glass back permitting
Re: Z900ltd Resto
Looking good Bill, coming along nicely!
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Re: Z900ltd Resto
Thanks Mr , had a hour on frame today putting front end and a couple of bits on ,soon be a roller so i can put it onto
proper bench and in corner out of way when any of others need owt doing on there like the z650c which needs its first
oil and filter change since rebuild
Re: Z900ltd Resto
stop showing pictures of the c2 it is cruel lovely work bill i need to get my finger out on mine
GPZ1100 A1 zrx1100 gsa1200
Re: Z900ltd Resto
ive got a z650 just for you mate USA import running for resto
Re: Z900ltd Resto
Hi Bill, the resto coming on great - a credit to you! One question: what did you use to clean up the crankcases, barrels etc? Have you lacquered yem after or left as is?
Thanks in advance and keep up the good work
Regards Pizzaman
Regards Pizzaman
Pizzaman
Re: Z900ltd Resto
Hello Pizzaman, a friend of mine has done it for me due to back surgery ,i just leave mine untreated
afterwards easy enough to keep clean if you start with it that way ,i glass bead blasted my Z1a but
the z650 i did was Philippes way brushwheels in drill and patience
Re: Z900ltd Resto
Fetched the bodywork back from painter today lovely job as usual Mr Dewes
Re: Z900ltd Resto
The engine is now ready to be reinstated when my son visits to pop it in there for me
