Page 2 of 3
Re: Z900ltd Resto
Posted: Mon Jun 10, 2019 2:16 pm
Author: kev edwards
That's coming along lovely Bill, skilled workmanship, just need to improve on your picture loading skills now as i am getting a cricked neck,
Re: Z900ltd Resto
Posted: Mon Jun 10, 2019 8:20 pm
Author: Bill P
Thanks mate
how the bloody hell do you get piccies right way up
Re: Z900ltd Resto
Posted: Tue Jun 11, 2019 7:32 pm
Author: kev edwards
Yours look like they are portrait, so before you load them edit them so they become landscape and they should load up properly
Re: Z900ltd Resto
Posted: Thu Jun 13, 2019 9:46 pm
Author: Bill P
My friend called in today so popped engine in frame for me
due to my back op, so ive spent the evening
bolting her in so now ive a rollin chassis with a engine in and paintwork back
so best get on with the wiring
harness
Re: Z900ltd Resto
Posted: Fri Jun 14, 2019 5:44 am
Author: Simonic
Bill P wrote: so best get on with the wiring
harness
Wiring!! It's the work of the devil...
Re: Z900ltd Resto
Posted: Fri Jun 14, 2019 1:13 pm
Author: Philippe
Hi Bill
you're on the right track!
Mind the demons and the gremlins in the loom! They're after your common sense and they try to make you crazy and to loose your mind.
Good luck with the electrics.
Re: Z900ltd Resto
Posted: Fri Jun 14, 2019 1:42 pm
Author: Bill P
Hello Gents thanks for your kind comments
i know what you mean they can drive you crazy but ive dropped very lucky with this and the z650
i finished earlier this year as both looms were more or less unmessed with
Re: Z900ltd Resto
Posted: Sat Jun 15, 2019 8:50 pm
Author: Bill P
Electrics well on way to being done now so decided to see what the Vance & Hines 4 into 1
looked like im pleased with it to
Re: Z900ltd Resto
Posted: Sun Jun 23, 2019 6:36 pm
Author: Bill P
Had a bit of time on the Z900 ltd yesterday and sorted the electrics also put on the Carbs so
nearly time to press the noisy button and see how she sounds with the Vance & Hines 4 into 1
then it'll just be a case of putting the pretty bits on ie repainted bodywork and waiting for a
reg number from DVLA
Re: Z900ltd Resto
Posted: Mon Jun 24, 2019 6:04 pm
Author: Bill P
Popped the throttle cables on today added the temporary fuel tank pressed the loud button and low and behold it
fired upon straight away
didn't run her long as air filter hasn't arrived yet ,so started to put bodywork back on
then a bit of brake bleeding then Bobs your Uncle she's done and onto the next
Re: Z900ltd Resto
Posted: Fri Aug 02, 2019 3:09 pm
Author: Bill P
Im nearing the end of the road with the Ltd project now , the DVLA is sending a inspector 5 Aug to check it as there was a discrepancy on NOVA
by D&K Motorcycles when they fetched it in and sadly not picked up by previous owner who's had it since 2014 and done nowt with her
ive fitted the airbox exhaust i bought from Australia a copy hopefully a couple of pics , i also bought the rubber bung for the hole in the
dash on my Z1 did they have somer there back in the day?
Re: Z900ltd Resto
Posted: Fri Aug 02, 2019 7:22 pm
Author: kev edwards
- 693789DE-9E64-48C9-9C80-0CE7CACAFE5D900ltd.jpg (125.54 KiB) Viewed 4794 times
Re: Z900ltd Resto
Posted: Fri Aug 02, 2019 7:37 pm
Author: Simonic
That's looking really good
Re: Z900ltd Resto
Posted: Fri Aug 02, 2019 7:44 pm
Author: Bill P
Thanks kind Sir, it'll end up being a relatively cheap 900 for just a bit of work
Re: Z900ltd Resto
Posted: Mon Aug 05, 2019 7:00 pm
Author: Bill P
Well the DVLA Inspector has been and gone and said he couldn't see any reason a reg number couldn't
be sorted for it but as he said there only contractors who don't even get to know why there checking
the vehicles anyway but says i'll know either way in 10 days
Funny thing was the first thing he said on arrival was its not a D&K Import is it
