New GPZ1100B1 project arrived today
Hi all,
So my new project arrived today. A GPZ1100B1 US import:
Now to decide what to do with it ?
My first thoughts were go original but …
It's been converted to carbs. Everything to do with the electronic ignition has been removed and the injector holes filled with metal putty.
Although the exhaust is reasonably good for the age it is a B2 exhaust (it has the Kawasaki badges)
Being a US import I expect going original will give it less value than a UK bike so is maybe less justified ?
I might be influenced by reasonable feedback but my probable plan is to go original paintwork (red) with 4 into 1, braided hoses, maybe a fork brace, maybe deep braced swing arm, maybe different rear shocks and leave the carbs.
If I go for a 4 into 1 I guess the exhaust will have some value. Any idea how much ? (it will help pay for other bits).
Its got a dent at the top of the offside down pipe and a small dent just in front of the indentation on the left side for the side stand. Considering age it's very good with no rot, a few scratches and original baffles
- Sgt.Pinback
Re: New GPZ1100B1 project arrived today
I´d give her correct paint and seat.
Good B1 seat for sale I have.
Carb wouldn´t bother me.
If you want sell the exhaust i´d offer you EURO 550 + shipping cost. Would like to see those dents anyway.
Cheers, Uli
Here are pics of the exhaust dents
- Sgt.Pinback
Ah, sadly the one on the downpipe is too big for me. Thanks.
Cheers, Uli
Hi JimBoUK
great project you have there! Very sad about the dent in the N°4 downpipe...
The exhaust of a B1 wasn't black chromed, it was painted black and it had no badges. The brackets were bolted on like on the B2. The GPZ1100 Uni-Trac had the brackets welded on the silencers.
It's a shame that the holes for the injectors in the head are filled with metal putty...but are you sure it's putty? Normally that would melt due to the heat of the burning gasses in the compression chamber. But OK, so be it.
I hope you succeed with your project and don't forget to put some pictures of your progress.
Don't put it back to standard, it'll be awful, flexible and dull. Relive your youth and do the mods as you suggest like you would've done back in the day - trust me, it makes an average bike into a good one!
(If you hadn't guessed I'm not a rivet counter - I don't get it as nobody had a standard bike back in the day....)
I agree with Coose.
Mod it as you would have done back in the day.
Make it how you'd have wanted it back in the day
don't the yanks luv a gaudy seat
Dents in the pipe can be taken out by filling with water and putting in the freezer....if you have a large enough freezer
Hi Jimbo,
I went to see the bike in the flesh and it's a great starting point. Whatever you choose to do it will be another Zed back on the road. Look forward to seeing how you progress with the project.
Gary.
Gary.
So I managed to get her running briefly before starting the strip down.
Actually sounded quite healthy
After a run, a compression check showed 3 were low with 1 only having 90psi
The strip down begins:
This project is going to take quite a while due to a lack of spare time.
So I wanted an engine stand which I could move if needed.
I found one by Sealey for about £80 but the weight limit was 75KG. I think the GPZ engine is a bit heavier than this so it might not be too stable.
I found another one but it was bench mounted and £160
In the end I got 2 car engine stands for £37 each and joined them together. After making some brackets out of angle iron it's just the job and is strong enough to hold any bike engine going.
Very pleased with the result and the engine can spin round as needed to do work
Next stage strip and rebuild the engine
Hi JimBoUK
that's very well done!
Good luck with the disassembly!
Coose wrote:Don't put it back to standard, it'll be awful, flexible and dull. Relive your youth and do the mods as you suggest like you would've done back in the day - trust me, it makes an average bike into a good one!![]()
I may have gone a bit too far with the above, we'll see when I get it back together and running properly
On the subject of engine stands, my engine is currently sat on a Workmate in RobW's garage
Great project and an excellent idea for your engine stand. One thing I'd forgotten about is how huge the clock binnacle was on those bikes, no need for a cockpit fairing....
Eight valve grunt.
Engine now stripped.
I'm looking for a new head instead of trying to fix all the butchered threads.
The rest is looking OK.
I've measured pistons, bores and rings which are all well within service limits.
Still gotta properly check everything else
The bottom of the engine was full of metal filings. These all fell back up into the engine when I turned it upside down.
I can't find any damage to cause this so assume it was a previous problem and the bits have been in the bottom ever since. Probably done when the head was butchered.
