Re: Hello to all - at last!!
Posted: Wed Feb 14, 2024 11:01 pm
Ultim8pc wrote:zed9 wrote:Thanks Ultim8pc carbs can be a nightmare sometimes though have set them up a few times.
Carbs were bought quite a few years ago from guy who had them just sat in damp garage for a while. Turns out No.3 had tip of air screw jammed in body which had snapped off and was a bugger to get it out without damaging body.
Are you sure you have the correct carbs for a z900? They have very chunky side mounted airscrews.
The later Z1000A1/2 had 28mm carbs with bottom mounted airscrews which often snap.
The ID stamped on the Z900 carbs is Z1200 and the Z1000A1/2 are 1025A.
They are not correct carbs for Z900 as they have air screw underneath carbs not on the side and thought they were from a z1000 though am sure they are 26mm not 28. Will have a look tomorrow see if i can find any ID on them and where its stamped.
