revs hanging a little
knut
#1 PostAuthor: knut » Sun Aug 23, 2009 9:42 pm
hi ,a question for the collective please,
what,s the most likely cause for the revs to just
hang for a sec after shutting the throttle ?
oops forgot the bike is z1000 a1,standard apart from
harris exhaust.also running standard air box and filter,
i,ve cleaned the slides and throttle cables and checked
the spring etc it,s snapping closed properly,
i,ve also checked the timing( static) at fully advanced
which is ok, should i retard it a little maybe ?
any help appreciated guys
MaineKZ
#2 PostAuthor: MaineKZ » Sun Aug 23, 2009 10:22 pm
Hi knut
This is usually caused by an air leak on the engine side of the carbs which causes induction to continue after throttle closing. Most common cause is failed airseal at the carb inlet rubbers.
#3 PostAuthor: Pigford » Mon Aug 24, 2009 7:26 am
AS JUST SAID... BUT IN MY LAWSON'S CASE...... :roll:
knut
#4 PostAuthor: knut » Mon Aug 24, 2009 10:32 am
thanks guys ,the rubbers don,t look too bad but guess it,s time for some new ones.
