Z1000 A1/A2 VALVES WANTED.
qwacker9
#1 PostAuthor: qwacker9 » Wed Aug 26, 2009 9:33 am
does anyone have a good set of valves for a Z1000 A1 / A2 going cheap or does anyone know where to buy new ones that dont cost an arm and a leg. or can bent ones be straightened ?
ive sold my best A2 so now im making a start on my project one. :wink:
Z1000 A2, GS1000E, RD250B,C,D,E. RD400D, 1976 FIZZY, 1973 SUZI AC50 & MORE.
PJ
#2 PostAuthor: PJ » Wed Aug 26, 2009 9:44 am
Hi Matey, it's got to be a no go on straightening them,
Just bought a set from Z1 enterprises, with postage about £100.00 per four valves
hillbilly
#3 PostAuthor: hillbilly » Wed Aug 26, 2009 2:05 pm
depending on which valve it is,i know that the toyota landcruiser 4.2 deisel engine,has the same size valves in them,all that is needed is them to be shortened.at about £8 each.could be a good saving. :wink:
steve f
#4 PostAuthor: steve f » Wed Aug 26, 2009 3:12 pm
i have a full set of inlet and exhaust valves second hand
PJ
#5 PostAuthor: PJ » Wed Aug 26, 2009 3:15 pm
hillbilly wrote:depending on which valve it is,i know that the toyota landcruiser 4.2 deisel engine,has the same size valves in them,all that is needed is them to be shortened.at about £8 each.could be a good saving. :wink:
Hillbilly,
Have you used them yourself?
hillbilly
#6 PostAuthor: hillbilly » Wed Aug 26, 2009 3:49 pm
i went to an engineering company for some head work,and they had a cd,that cross referenced valves,and found that the valves from a deisel toyota land cruiser was the same size in width and size,the stem was longer,but he said you can cut them down and regrind the collet holders. :lol:
DogsbolloxofZ1B
#7 PostAuthor: DogsbolloxofZ1B » Thu Aug 27, 2009 7:28 am
I bought a full set of patern ones from ZedPower for ~ £150, had to grind the valve stems down 0.020" as a little long but otherwise OK.
