Z1000LTD
Z1000LTD
Is there much difference between the LTD frame (1980) and standard Zed frames? Mainly interested in head stock rake/angle & rear end set up, due to 16" wheel. Could an Z1000LTD frame be used as a base for making a standard Z1000?
- paul doran
Iain marshall
Pigford all the Ltds up to the J engined ones (K1) used a frame based on the Z900 style,to convert to a standard looking change back wheel for 18 inch one,fit a standard z1000 tank and thats about it,heres a pic from Redlinecycles who deal in a lot of LTDs ,standard and modified
http://www.redlinecycle.com/home.html
- london calling
The Z1000LTD (K) has a different frame to the 1000J,different footrest hangers,different forks,bodywork,rear wheel is 16".
If you want to fit an earlier Z motor instead of a J type motor,you'll have to change the engine mounts as well.
Definitely not a 5 minute job.
Last edited by london calling on Sun Mar 04, 2007 5:42 am, edited 1 time in total.
Jack
Iain marshall
Pigford that one there looks like a CSR/LTD,CSR had wire wheels,LTD alloy wheels.The frame on these bikes ,J motor,are totally different to the standard frames,seat rails are lower and the steering angle different,also the forks are leading axle type.I thought about changing the Spectre to a more "normal"looking style but there were too many things to change
- london calling
Iain marshall
Iain, must admit, looks quite tasty! Cheers for advice about frame
Gonna swap the bars first thing! Have to keep me eye out for some nice pipes & maybe a 'J' style tank too!
I do like the alloy rims/spoked wheel tho! Gonna do some polishing (M I K E Y)
Bike has standard CV type carbs & K&Ns, but probably not jetted to suit.
May do a nice old skool STREETFIGHTER jobbie
- london calling
