Can any one help me 3 number 7 bolts needed, can get them refurbed so rusty not a problem
need 2 for the handlebar mounts for the master cylinder and 1 for the clutch perch.
NUMBER 7 BOLTS wanted
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
Re: NUMBER 7 BOLTS wanted
bedlow1 wrote:Can any one help me 3 number 7 bolts needed, can get them refurbed so rusty not a problem
hard to get hold of, can get no 4's in 6mm. no 7's in 8mm and above. what
length you after, 25 or 30mm.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
The number on the head of the bolt is it’s tensile strength, they are used on all Japanese bikes over the period, the “7’s†are used in places where security is important ( bit of overkill on the clutch perch) The “4’s†are also a common sight on Japanese bikes. Anyway, Back to the plot – the “7’s†requested are in a chrome finish, and unfortunately they often come with a captivated flat washer which makes them even rarer – and just to cap it all there are 4 different styles of font on the “7†figure throughout the 1970’s 2- what year "7's" are you after ?
Lifes too short . . .
- ZedHead
Graham I've got two no.7 bolts with the captivated washers they are 25mm and a no. 4 bolt with captivated washer which is 30mm, they will need a rechrome. Your welcome to them if you want, if any use to you PM your address and I'll post them straight off to you.
Couldn't tell you which font they are though.
