Yellowing of chrome
Z1B Alan
Yellowing of chrome
#1 PostAuthor: Z1B Alan » Mon Nov 02, 2009 2:49 pm
A minor point but is it possible to polish out slight yellowing of the chrome header pipes if so what is the best produvt to use :?: .
#2 PostAuthor: kev edwards » Mon Nov 02, 2009 3:15 pm
Hi Alan
it is possible to polish out the yellow with things such as autosol,but the chrome is only decorative and only a few microns thick and polishing will remove some of the chrome,it will then yellow and blue up again,eventually you will polish off the chrome and the subsrata of nickel and then the areas will rust very quickly,i actually like the yellowing on the pipes it shows they are used.
bigmac103
#3 PostAuthor: bigmac103 » Mon Nov 02, 2009 5:56 pm
Blue Job, i did my pipes. Works really well but yellowing will eventually come back and you have to do them again. If it helps here's the place I use.
https://www.lgogroup.net/www.sportouring.com
Before
After
Lost in the desert somewhere
02GF74
#4 PostAuthor: 02GF74 » Tue Nov 03, 2009 9:09 pm
.... surely that is just a wasate of time since when they heat up, the same will happen again?
personally I like the blued exhaust look.
.... but back to the Q. frosts sell this
but £ 17.50 !!! leave them blued!!
KeithZ1R
#5 PostAuthor: KeithZ1R » Tue Nov 03, 2009 9:44 pm
Nice shorts :oops: :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
