Yellowing of chrome
Yellowing of chrome
A minor point but is it possible to polish out slight yellowing of the chrome header pipes if so what is the best produvt to use
Hi Alan
it is possible to polish out the yellow with things such as autosol,but the chrome is only decorative and only a few microns thick and polishing will remove some of the chrome,it will then yellow and blue up again,eventually you will polish off the chrome and the subsrata of nickel and then the areas will rust very quickly,i actually like the yellowing on the pipes it shows they are used.
Blue Job, i did my pipes. Works really well but yellowing will eventually come back and you have to do them again. If it helps here's the place I use.
https://www.lgogroup.net/www.sportouring.com
Before
After
Before
After
Lost in the desert somewhere
