Tool Kit Bit
Kev1R
Tool Kit Bit
#1 PostAuthor: Kev1R » Fri Nov 20, 2009 1:53 pm
I had cause to go into my tool kit this year for the first time for years, and found that the nut & bolt, which holds the pliers together had disappeared. I have tried afew odd nuts/bolts combinations but obviously not the right size as I can’t get them to work properly. I suspect the bolt shaft is different diameter (and not threaded),to bit the nut screws on to.
Can anyone confirm this, or post a pic, or better still,- has anyone got this item spare, that they would be happy to part with in exchange for dosh.
Kevin
02GF74
#2 PostAuthor: 02GF74 » Sat Nov 21, 2009 11:33 am
if you are not bothered about originalily, can you not drill out the hole in the pliers?
and you have tried metric and imperial bolts?
or you could use a bolt and a sleeve so it is a snug fit.
Taffus
#3 PostAuthor: Taffus » Sat Nov 21, 2009 12:09 pm
02GF74 wrote:if you are not bothered about originalily, can you not drill out the hole in the pliers?
OOh you devil, TLC will be along soon to sort you out! :D He'll be able to confirm whether you need a number '7' or '4' bolt and what the correct plating should be...... :D
phil churchett
#4 PostAuthor: phil churchett » Sat Nov 21, 2009 12:51 pm
:rir :rir :rir
