engine clean
taynton
engine clean
#1 PostAuthor: taynton » Sun Mar 25, 2007 12:29 pm
anybody got any ideas how i can clean all the years of muck of the front of the engine. the bikes been standing for 5years
london calling
#2 PostAuthor: london calling » Sun Mar 25, 2007 5:45 pm
Get some TFR (traffic film remover) and brush some on.Then wash it off,a hot power wash will help.Please be aware that neat TFR is strong stuff so be carefull with paintwork,etc.
Jack
Jerry
President
President
#3 PostAuthor: Jerry » Sun Mar 25, 2007 6:25 pm
I've never prsonally used it, so please check it out first, but if the engine is reeeelly shitty, mister muscle oven cleaner works wonders, but wash it off after 5 mins each application.
#4 PostAuthor: Rich » Sun Mar 25, 2007 6:30 pm
Jerry wrote:I've never prsonally used it, so please check it out first, but if the engine is reeeelly shitty, mister muscle oven cleaner works wonders, but wash it off after 5 mins each application.
and your best to neutralise the alkaline after with a wash of one part vinegar to 50 water.
MaineKZ
#5 PostAuthor: MaineKZ » Sun Mar 25, 2007 6:49 pm
If you're careful, you can used an acid based water soluable cleaner like Ali-brite, but be aware this will remove the cad or zinc from your fasteners if you leave it on too long, so use it on small areas at a time. Apply, rinse, several times. The acid removes oxides from the ali leaving it 'bare', so you need to dry the engine off after the job, don't leave it wet or you'll have a furry white oxide-coated engine next morning! :shock: Any ali wheel cleaner will do the same job, so will brick cleaner for that matter - but dilute that stuff first - it's fierce!! Lastly, protect the cleaned area with a preservative oil like Motorex.
Surfdeneige
#6 PostAuthor: Surfdeneige » Sun Mar 25, 2007 9:07 pm
you can't beat GUNK, brush it on or spray and brush, work it in and jetwash it off. Works wonders.
A ken fit like!
bedlow1
#7 PostAuthor: bedlow1 » Mon Mar 26, 2007 9:48 am
i use muck off, and a cold gentle pressure wash on my z1b. Be careful of the steam cleaners and solvents, saw a z1a that bernie at beezees had done and it left him with a lot of work polishing up all the covers as they all went milky!
1972 Z1 Euro Spec
1975 Z1B UK Bike
