another starter motor fault
is there a way to pinpoint if its a switch or motor fault? battery ok and no "click" from the solonoid?
Even if the starter motor is stuffed you should still hear a click from the solenoid.
To test if the starter motor is ok you could strike a spanner briefly across the starter motor connections on the solenoid.
If you have a multimeter you could check that the solenoid is getting power when the starter button is pressed.
wilsonsjw11
wilsonsjw11 wrote:Wayno
Following on from Pasc,check you have continuity through the coil by testing across the 2 soldered terminals on the solenoid with a multimeter set on ohms you should get between 3 and 4 ohms.
Regards
Steve
yes steve i get 3.6 ohms. if a screwdriver across the 2 main terminals then the motor turns so not the motor, how do i test the switch?, tried various ways but not sure how it should be done. got the battery on charge overnight in case but did read over 12volts but died really quick when testing with the screwdriver. did think of jumping form the van without engine running.
wilsonsjw11
Wayno
Testing the switch; ignition off open up the switch body and with your multimeter set on ohms test across the switch contacts,you should have 0 ohms or there abouts with the button pressed if its high resistance(k ohms)it could be dirty or burnt contacts,if this is ok check for continuity from the dead side of the switch to one side of the solenoid(look at circuit diagram)if this ok turn on the ignition and check you have got 12volts on the other side of the switch.
Regards
Steve
Regards
Steve
wilsonsjw11
wilsonsjw11
Hi ,the starter button switches the negative not the positive ,if my memory serves me correctly there is a contact to the handle bars fron the switch assembly make sure this is making good contact there should be 12v positve to one side of the solenoid when the ignition is switched on(small diameter cable )when you press the starter switch you make the circuit through the solenoid windings to negative(the frame) Hope this helps Paul J..
wilsonsjw11
