Z1000J engine spacer dimensions
#1 PostAuthor: Ginger Bear » Sun Dec 06, 2009 12:31 pm
Can anyone confirm the width of these two spacers. The ones pictured came from a GPz1100 Unitrac. They are both on the left hand side of the bike, one at the front & one at the rear. This engine is now fitted in a 'J' frame & I need to be sure these are the correct size.
Thank you!
# 104
#2 PostAuthor: Al » Sun Dec 06, 2009 1:29 pm
The long spacer (LHS) is 55mm in length
The short spacer (RHS) is 30mm in length
Stud is 12mm OD
Front spacer is not circular but a horseshoe shape and is 4.5mm thick
Rear bracket before paint is 4.5mm thick (the one pictured with the stop switch mount)
P.S.
My No. 4 exhaust header is dangerously close to the front frame tube so it has to be dead right or better!!!
#3 PostAuthor: Ginger Bear » Sun Dec 06, 2009 1:37 pm
Thanks again Al,
That is a great help. Only need to fit engine to sort out chain alignment & that large 55mm spacer is crucial. Luckily the one in there is 55mm. I'm just pleased to know I have the correct size. Thankyou Thankyou.
# 104
Users browsing this forum: No registered users and 73 guests
