Clock Damper Rubbers
Keith
#1 PostAuthor: Keith » Sun Dec 13, 2009 9:28 pm
Anyone point in in right direction for these - they are the small ones that cushion the actual clocks on the meter bracket - not the 4 meter bracket ones, if that makes sense
Also is anyone doing the cushioning they sit on?
Keith
Steve S
#2 PostAuthor: Steve S » Sun Dec 13, 2009 9:44 pm
Z Power should be able to help you with the rubbers,someone else on here may be able to help you with the foam.I used some self adhesive foam sheet from Hobby craft just shape and cut to fit....Simples!!!.....squeak :D
z2.john
#3 PostAuthor: z2.john » Sun Dec 13, 2009 9:45 pm
Haven't checked recently but think they are still available.
As for the foam pads the clocks sit on, you can make these yourself quite easily.
phil churchett
#4 PostAuthor: phil churchett » Sun Dec 13, 2009 9:46 pm
Keith,
i think tailiftchris will be able to help with the foam.
Keith
Clocks
#5 PostAuthor: Keith » Sun Dec 13, 2009 9:58 pm
Thanks for help so far
Couldn't find them on the Z Power site - only the bracket dampers
Tailiftchris - if yuu read this can you help?
Keith
tlc
#6 PostAuthor: tlc » Sun Dec 13, 2009 10:00 pm
Users browsing this forum: No registered users and 83 guests
