cyl head
baz
cyl head
#1 PostAuthor: baz » Mon Dec 14, 2009 7:23 pm
can anyone tell me if a z1ooo head will fit a z900 eng. cheers
#2 PostAuthor: Pigford » Mon Dec 14, 2009 7:32 pm
Yes
Alexander
#3 PostAuthor: Alexander » Mon Dec 14, 2009 7:39 pm
Hi Baz,
will fit no problem, main difference is 8mm exhaust studs in stead of the 900's 6mm but you can drill out exhaust pipe retainers to suit or obtain z1000 set. Obviously a MK1 head is preferable as the later heads although will fit can have a more square shape to them. Might be best to advise what model of Z1000 head you have as some even later models can be fitted with modifications, but there are plenty of experienced experts here that would be willing to advise if this is the case. Alex.
Alexander
#4 PostAuthor: Alexander » Mon Dec 14, 2009 7:41 pm
Hi Baz,
will fit no problem, main difference is 8mm exhaust studs in stead of the 900's 6mm but you can drill out exhaust pipe retainers to suit or obtain z1000 set. Obviously a MK1 head is preferable as the later heads although will fit can have a more square shape to them. Might be best to advise what model of Z1000 head you have as some even later models can be fitted with modifications, but there are plenty of experienced experts here (not me) that would be willing to advise if this is the case. Alex.
baz
#5 PostAuthor: baz » Mon Dec 14, 2009 8:08 pm
thanks for that, he's not sure what model it came off but says its got cam shells fitted and 6mm ex studs. is that any use :?:
#6 PostAuthor: kev edwards » Mon Dec 14, 2009 8:19 pm
6mm exhaust studs? that would be a 900 head correct me if i'm wrong? :)
hillbilly
#7 PostAuthor: hillbilly » Mon Dec 14, 2009 8:32 pm
yep defoe a 900 head.
baz
#8 PostAuthor: baz » Mon Dec 14, 2009 8:45 pm
what about shells though :?: were they only fitted to the thou.
#9 PostAuthor: Pigford » Mon Dec 14, 2009 9:53 pm
All got shells :wink:
#10 PostAuthor: PAULJAC47 » Mon Dec 14, 2009 9:54 pm
If you mean cam shells they are certainly on a 900 head 6mm studs mean it is probably a 900 Cheers paul J..
