650 bits
ted1r
650 bits
#1 PostAuthor: ted1r » Tue Dec 15, 2009 7:05 pm
Lads in Z land has any one got any 650 bits like a manual or seat in good nick,front master cylinder and splitter,speedo,anything else you can think off.
Os front engine mount plate.
Regards Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
PaulMceleney
Chunks
#2 PostAuthor: PaulMceleney » Tue Dec 15, 2009 7:23 pm
good back wheel
ted1r
650 bits
#3 PostAuthor: ted1r » Tue Dec 15, 2009 7:24 pm
Got that thanks
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
kawamick
#4 PostAuthor: kawamick » Tue Dec 15, 2009 7:39 pm
I have the square master cylinder. The same one like the z1000A2 MK2.
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
m1ks
#5 PostAuthor: m1ks » Tue Dec 15, 2009 8:18 pm
Got a H***es manual on PDF, files about 27mb but can lob on a sharing site for you to download if any good?
Failing that can print one off and post but will have to ask a bit to cover paper, ink and postage?
Notice you're in Cleethorpes, not been down that way in ages, lived in Skeggy for a couple of years a while back, :)
You know you're getting old when you stop laughing at nasal hair trimmer adverts and start thinking, hmmmm.... you know, that looks useful!
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Tue Dec 15, 2009 9:35 pm
Might have a front engine plate, but wont know till Jan when I get all my spares back. As I have had to rebuild my workshop.
I also know someone who can make you a qaulity seat cover if you have the original that can be used as a pattern.
Just had one made for a 2-4 for my 650 and its ace.
#7 PostAuthor: kev edwards » Wed Dec 16, 2009 9:38 am
my brother has lots of engine parts,im sure he will sell them at good prices.
ted1r
BITS
#8 PostAuthor: ted1r » Wed Dec 16, 2009 1:28 pm
Thanks for the response lads ,I have sent pm`s
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
zedrider
#9 PostAuthor: zedrider » Fri Dec 18, 2009 11:04 pm
i have a splitter for a single disk set up . a have z650 parts carbs etc . pm me with your whants .
zed
Crofty
#10 PostAuthor: Crofty » Thu Dec 24, 2009 12:30 am
I have a few bits, put aside from my current rebuild. Front master cyl triangular shape, top cover damaged on it tho and actual resevoir minor chamfer on one corner. A good used genuine piston for front caliper as well. Airbox with screw on top cover, the previous owner has enlarged the holes to the carbs slightly! plus a lot of engine bits in good order. US cam cover.
