G'day blokes,I'm after the 8 collets for a Z1000 Harris pipe.
Are there any collets out there......
HARRIS 4-1 EXHAUST COLLETS
- PETER KZ1A
- london calling
G'day Peter,have you tried using your existing exhaust collets ??
When I swapped my 4-4 Z900 exhaust for a Vance & Hines,I used the standard Z900 exhaust collets
Z-POWER in the U.K. (and I guess Z1 ENTERPRISES in the U.S.A.) can supply new ones if you're un-able to get a s/hand set.
Hopefully someone on here will be able to help you out.
Jack
- PETER KZ1A
HARRIS 4-1
Thanks for the reply.The collets are same for 900 and 1000,same part #,the Harris pipe is a bigger diameter,guess I should contact Harris
- london calling
Norman Hyde took over the Harris Works Collection series. His site is here;
http://www.normanhyde.co.uk/search.php?tag=51
Rod
Rod
