Expecting main stand back from coating next week - spring was dead tight to get off and I'm keen not to damage the stand or frame repaint when it goes back on. Anyone done this recently and worked out a good method - the 650 has a long spindle that goes through both sides of the stand from the same side as the spring which fits down the side of the stand.
Thought about prising some dowel between coils of the spring to open it a bit - could a big G clamp be adapted into a spring puller? Any ideas or pics of how you've done it would be most welcome. From Mark in Staffs.
