JET SIZES
blackdog3
JET SIZES
#1 PostAuthor: blackdog3 » Fri Feb 12, 2010 9:09 pm
changed a gpz1100a2 to carbs . got a std filter,cobra pipe ,no baffles. any ideas on jet sizes. cheers
#2 PostAuthor: Pigford » Fri Feb 12, 2010 10:14 pm
If they're std older GPz1100 carbs (BS34), the mains are approx 125, so with an open pipe start at 130 :wink:
blackdog3
JET SIZES
#3 PostAuthor: blackdog3 » Sat Feb 13, 2010 9:25 pm
the carbs are off a z1000 j2
nanno
#4 PostAuthor: nanno » Tue Feb 16, 2010 8:13 am
130 - 135
I am running 135s on my Z1000J and it seems to work reasonably well.
Greg
dimble
#5 PostAuthor: dimble » Wed Feb 17, 2010 9:04 am
Interesting question. Not sure about my english here, but what about the idle jets and screws...? :?? thanks
#6 PostAuthor: kev edwards » Wed Feb 17, 2010 9:27 am
An f4 Phantom is quite big :)
#7 PostAuthor: Pigford » Wed Feb 17, 2010 10:08 am
dimble wrote:Interesting question. Not sure about my english here, but what about the idle jets and screws...? :?? thanks
Pilot jets may need to go up a size (eg: from 17.5 to 20) and th air screw will just need to be fine tuned :wink:
dimble
#8 PostAuthor: dimble » Thu Feb 18, 2010 12:47 pm
Ok pilot jet and not idle ...thanks for the lesson :)
How to fine tune the air screws. Someone told me about pointing each exhaust and measure the temp and adjust...Do you have a simpler method? :wink:
#9 PostAuthor: Al » Thu Feb 18, 2010 5:01 pm
You could do worse than buy these to set up the carbs and in particular the 'air' (fuel) screws.
http://www.ekmpowershop20.com/ekmps/sho ... s-25-p.asp
This is a special offer which saves a few quid!
As a general guide to setting up the rest and interpreting what you get with the above mentioned you might follow this.
http://www.mikuni.com/fs-tuning_guide.html
Do you mean painting the exhausts??
You can tell a lot about initial temperature gains by putting candle wax on the uppermost exhaust stud of each cylinder and seeing which come up first and of course last.
Also useful if youve got a cylinder down and dont want to burn youre hands.
dimble
#10 PostAuthor: dimble » Fri Feb 19, 2010 6:23 am
i was thinking paint :oops: but pointing each exhaust with a laser temp meter...
Users browsing this forum: j.b and 79 guests
