Z1R Battery case brackets wanted.
ruffle
#1 PostAuthor: ruffle » Sat Feb 13, 2010 12:05 pm
I'm after a couple of brackets that attach to the battery case for my Z1R.
The first one seems quite common to a number of 'thous' and it's the one that sits on top of the battery to hold it down:
No 14 on the parts diagram, Kawasaki Part No 32100-100 "BAND,BATTERY"
The second seems unique to the Z1R (why such variation on the battery case between models?) and it's a plate that bolts to the right hand side of the battery case and provides a mount for the regulator.
No 16 on the parts diagram. Kawasaki Part No 11034-1732 "BRACKET,BASE,R.H"
although the Kawasaki US site says it was superceeded by 11034-1056 "BRACKETBATTERY CASE"
Anyone got either of them kicking around?
TIA
kawamick
#2 PostAuthor: kawamick » Sat Feb 13, 2010 12:45 pm
No 16 is not for the z1R D1
Only the 1980 D3 has this plate.There is a black box on it: Part No 27010-1007 SWITCH,RESERVE LAMP and the IC igniter.
Here is a pic of my D3 that is still waiting for warm weather. :roll:
Mick
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
ruffle
#3 PostAuthor: ruffle » Sat Feb 13, 2010 2:56 pm
Ummm.... the parts diagram I included is for the '78 and shows the bracket.
As it came (without said bracket) here's what the right hand side looked like. The regulator doesn't seem to sit 'right' but perhaps it's the wrong reg?
Anyone got a picture of the RHS from a '78?
compo z1r
ruffy
#4 PostAuthor: compo z1r » Sat Feb 13, 2010 5:34 pm
ruffle wrote:Ummm.... the parts diagram I included is for the '78 and shows the bracket.
just ask the experts :lol: :lol:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r
ruffy
#5 PostAuthor: compo z1r » Sat Feb 13, 2010 5:40 pm
ruffy ill' have a look for a battery band :lol: :lol: and you'll need the rubbers for mounting. footrest brackets new or s/hand.
:lol: :lol:
lta01
#6 PostAuthor: lta01 » Sat Feb 13, 2010 5:51 pm
Hey Compo, only trying to help here, not be a smart ar*e...... in the last picture showing ( I assume ) your bike, it looks like the rear brake hose has been connected the wrong way around at the master cylinder. Shouldn't the banjo curve backwards ...the way it is, looks like its putting strain on the crimped hose joint, which will be aggrevated when the suspension travels up.
Just been out to the garage and checked which way mine turns.... its back towards the caliper.
He who dies with the most toys wins .
compo z1r
z1r
#7 PostAuthor: compo z1r » Sat Feb 13, 2010 8:33 pm
[quote="lta01"]Hey Compo, only trying to help here, not be a smart ar*e...... in the last picture showing ( I assume ) your bike, it looks like the rear brake hose has been connected the wrong way around at the master cylinder. Shouldn't the banjo curve backwards ...the way it is, looks like its putting strain on the crimped hose joint, which will be aggrevated when the suspension travels up.
Just been out to the garage and checked which way mine turns.... its back towards the caliper.[/quote
correct smart ar*s :lol: :lol: :lol: but as this bike is not used i put it that way to lay pipe as flat as poss across swing arm theres a few other mod ive' done too :wink: :wink: .
tlc
#8 PostAuthor: tlc » Sat Feb 13, 2010 8:58 pm
ruffle wrote:Image
You`ll be wanting to change those cylinder mounting bolts for stainless ones ?
And giving me the horrible rusty #4`s :D
ruffle
Re: ruffy
#9 PostAuthor: ruffle » Sun Feb 14, 2010 9:09 am
Rats. Looks like I've the wrong regulator (or someone's cut the mounting tab off one side; I've not looked that closely).
Looks like I'll have to cancel my standing EBay search for the bracket and put one in for the reg :(
ruffle
#10 PostAuthor: ruffle » Sun Feb 14, 2010 9:17 am
I thought your garage would be creaking under the weight of stashed #4's by now :)
But if you need them then yes you can have them.
Users browsing this forum: Google [Bot] and 15 guests
