carb rubbers rock hard any tips ?
marve114
#1 PostAuthor: marve114 » Sun Feb 14, 2010 11:29 am
hi guys got my z1000j running the other day all good but it only idles
or revs up with the choke on i reckon it could do with the carbs cleaning .
But the airbox rubbers have gone like PLASTIC :shock: so would make removal and putting them back on hard work
have you got any tips tor sofening them up again or got a soft set spare :?:
many thanks in advance
lee
coldsummer
#2 PostAuthor: coldsummer » Sun Feb 14, 2010 11:36 am
I find applying heat with a hairdryer is quite effective. Just remember to put it back in wife's/girlfriend's/daughter's bedroom exactly as you found it and make sure there is no grease or oil on it :wink:
For reassembly you could always stick them in some hot water to soften them up prior to refitting.
#3 PostAuthor: kev edwards » Sun Feb 14, 2010 11:50 am
As Coldsummer says,but really the best option is to buy new ones i did
marve114
#4 PostAuthor: marve114 » Sun Feb 14, 2010 11:53 am
were could i get a set from ?
nigel bessant
#5 PostAuthor: nigel bessant » Sun Feb 14, 2010 12:07 pm
For reassembly you could always stick them in some hot water to soften them up prior to refitting.[/quote]
A plumber friend of mine said to soften the fibre tap connector washers in hot water before fitting them for a leak free joint. So there ya go!
Also, instead of a hair dryer you could use one of those paint stripping guns and you can get it as grubby as you like without trying to clean it with a substance that leaves no smell, cuz she WILL know!!
ted1r
post
#6 PostAuthor: ted1r » Sun Feb 14, 2010 12:32 pm
Waste of time with old ones ,there not dear. I just got a set for the GPZ750 from Z power for £8 each posted.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
marve114
#7 PostAuthor: marve114 » Sun Feb 14, 2010 1:02 pm
very helpfull thanks you guys
z power i was :shock: to find the rubbers £8.50 each will get some when i get paid
london calling
#8 PostAuthor: london calling » Sun Feb 14, 2010 5:02 pm
Z-POWER give Z1OC members discount on all purchases.
Jack
pertonpc
#9 PostAuthor: pertonpc » Sun Feb 14, 2010 5:15 pm
You can soften up old airbox to carb rubbers by soaking them in acetone. I've seen it done on a video and it was amazing. Effect lasts for about 4 months according to the commentary with the DVD. From Mark
paul hart
#10 PostAuthor: paul hart » Mon Feb 15, 2010 10:55 am
As z1r says,you are wasting your time with old stuff,Z Power will fix you up without breaking the bank.
phil churchett
#11 PostAuthor: phil churchett » Mon Feb 15, 2010 11:09 am
And to keep the new ones supple, Armorall is good stuff.
http://www.armorall.eu/uk/
marve114
#12 PostAuthor: marve114 » Mon Feb 15, 2010 6:44 pm
thanks guys i will try get them off and clean them out i will try a lil bit of acetone keep you posted :wink:
Users browsing this forum: Google [Bot] and 63 guests
