Fitting Dyna Coils...
uk kev
#1 PostAuthor: uk kev » Tue Apr 17, 2007 8:07 pm
I am toying with the idea of fitting Dyna coils to my Z1000, but in my research I found this line on the Z1 Enterprises site.....
For some Kawasaki bikes with a resistor in the circuit (i.e. KZ1000's in the late 70's and early 80's), the 3 ohm coil is the best choice - just remove the ballast resistor from the circuit.
So where would I find said ballast resistor, if I have one fitted?
#2 PostAuthor: Rich » Tue Apr 17, 2007 8:28 pm
Between the feed from the ignition switch and the coils but I doubt you have one. They were fitted to Mk2s mainly and I would expect that you have 4 ohm coils.
uk kev
#3 PostAuthor: uk kev » Tue Apr 17, 2007 8:40 pm
Thanks Rich, tank will be off this weekend, so I guess I will find out then.
Jeff Saunders
#4 PostAuthor: Jeff Saunders » Wed Apr 18, 2007 1:46 am
1979 & 1980 1000's had a 1.5 ohm ballast resistor - these bikes had electronic ignition from the factory.
uk kev
#5 PostAuthor: uk kev » Wed Apr 18, 2007 6:32 pm
cheers Jeff.
