Dyna coils - ht lead routeing
Kev1R
#1 PostAuthor: Kev1R » Sat Mar 06, 2010 10:13 am
Does anyone have a photo (or advice) of Dyna coils fitted. - It is particularly the routeing of the ht leads I am interested in - Not the coils themselves as they are now on.
The best route I can see is to let the leads 'bunch up' in the headstock area (particularly the forward most pair) and then loop back 180 degrees to the top of the engine. Am I missing something - is there another way?
#2 PostAuthor: chrisNI » Sat Mar 06, 2010 12:07 pm
That's the way I've always had mine.
#3 PostAuthor: Pigford » Sat Mar 06, 2010 1:46 pm
The coil H/T leads should be pointing to the rear of the bike - away from the headstock :!:
#4 PostAuthor: Rich » Sat Mar 06, 2010 4:24 pm
You should not run leads bundled together as they induce cross fire to other plugs. Crossing at 90 deg is Ok.
Dyna also advise that the secondary towers face forward.
http://www.dynaonline.com/skins/downloa ... rdCoil.pdf
Personally I go for the shortest route (too tight to buy lots of HT lead :D ) and try not to run them parallel
Kev1R
#5 PostAuthor: Kev1R » Sat Mar 06, 2010 4:35 pm
Ok - thanks for responses so far - the set up in the pics is nothing like mine. I have the green coils and they are mounted above the top rail
I have just taken the bike for a quick spin round the block and it seems ok. As for not running the leads together - its difficult to keep them apart as they all seem to want to converge in the same physical place.
Kevin
#6 PostAuthor: Pigford » Sat Mar 06, 2010 7:00 pm
Main thing is to be aware that the mounting posts run VERY close to the low tension screws :?? That is BAD.....
Kev1R
#7 PostAuthor: Kev1R » Sat Mar 06, 2010 9:50 pm
ok many thanks again
#8 PostAuthor: chrisNI » Sat Mar 06, 2010 11:06 pm
The the early bikes take the green ones and they go above the rails and face forward.
Rich wrote:You should not run leads bundled together as they induce cross fire to other plugs. Crossing at 90 deg is Ok.
Rich I never had a misfire on mine and the leads were all together in there for years maybe the Dyna leads are well insulated?
GUYZED
#9 PostAuthor: GUYZED » Sun Mar 07, 2010 8:48 am
This is how i've got mine...facing forwards.
Hope it helps :D
#449
Z1000A2 Z650B1
#10 PostAuthor: Pigford » Sun Mar 07, 2010 9:51 am
Ahhhh, yes, me older Z1000 does have them like that - :oops:
#11 PostAuthor: Ginger Bear » Sun Mar 07, 2010 4:21 pm
Here's how I did mine;
Note the heatshrink on the mounting pillar to avoid the low tension lead shorting out.
# 104
Mark Stratton
#12 PostAuthor: Mark Stratton » Mon Mar 08, 2010 1:47 pm
GB
Is that the relay mod that everyone seems to advise and if so which relay do you use and where do you get them?
#13 PostAuthor: Ginger Bear » Mon Mar 08, 2010 4:28 pm
Mark, That is the 'relay mod'.
It came from my local motor part store. I bought it as a spotlamp wiring kit, it came with some heavy duty cable & connectors. Didn't cost much more than a fiver if I remember correctly.
# 104
cra-z1
#14 PostAuthor: cra-z1 » Tue Mar 09, 2010 3:08 am
Looks like we got a consenses on how to do it. I added heat shrink later(not shown)Image
coldsummer
#15 PostAuthor: coldsummer » Tue Mar 09, 2010 8:21 am
Looking at those pics, I'm starting to worry that mine won't clear the frame bracing on mine?
Users browsing this forum: Robw and 42 guests
