Float Issues
#16 PostAuthor: Pigford » Mon Mar 08, 2010 6:38 pm
All the float valve is an ON-OFF switch, so as long as its working nicely, and metering the fuel to the right height, should be OK - Suck & see :wink:
#17 PostAuthor: Rich » Mon Mar 08, 2010 6:46 pm
You ought to put a pin through the pivots then take a look at the alignment.
Alexander
#18 PostAuthor: Alexander » Mon Mar 08, 2010 9:19 pm
Additional sealing ring idea seems sound enough to me John.
