Gents, I am having a hell of a time trying to find a set of 4 of the O rings that seal the float bowl drain screws for a 1974 Z1A. I saw a set on ebay and now it looks like they are gone daddy gone. Does anybody out there in Zedlandia have a set or a source?
I found some that are close at the hardware store but the size is just not right and some minor seepage is the result.
Carb O Rings Needed
- Surfdeneige
I used to use these monkeys for work. Give them any o'ring and they will give you a new one or 100 for ?2.35 or so. They will also tell you material type, Viton, Buna N etc http://www.brammer.biz/home_uk.aspx
A ken fit like!
