Desperately seeking rear wheel spacer for a Z1b. It's the one that goes between the sprocket carrier and hub, not the other one that looks like a cotton reel. This is the part no; 42036 015 sleeve.
I would be very grateful!!
Alternatively, borrow one to use as a pattern to get another made up?
Z1b rear wheel spacer
- coldsummer
hillbilly wrote:is it the one that looks like a big washer,the same size as the bearings.
Hi Hillbilly - it is about 42mm long with a raised lip in the middle, one end sits inside the bearing in the sprocket carrier and the other meets the face of the hub bearing. It's not the flat one. Cheers, Simon.
- coldsummer
- ZedHead
- coldsummer
- coldsummer
Thats good news Simon, i was unable to find item even though i had a good look through my box of bits....Paul J..
- coldsummer
