Having gone to the Dyno day and got a disapointing 63 bhp for my Z1170 with Keihan carbs, obviously something is not quite right. I spoke to the chap and he showed me the dyno graph, it climbs quite rapidly and looks like a normal shape graph, but tops only 63 bhp.
At full chat black smoke was coming out of the exhausts and I have noticed it does use a bit of petrol.
He said that it seemed to be running really rich, looking at the plugs No 2 and 4 are very black, 3 and 1 look normal. Other comments from people watching said it sounded wooly.
It happily revved through the redline and acclerates really well on the road, with what seems enough power.
I have took of the head and the timing was correct and I could not see any problems with the bore. Although one bore did seem to have a lot of petrol in it.
I am aiming to fit the new head and take it to Seastars to be set up on the dyno, but want to make sure nothing else could be wrong before rebuild
Would excess fuel cause a power drop like this?
Cheers Rob
Dyno dilemas
Dyno dilemas
- big green bus
I had 92 with 1075 kit, 29 s/bores and a slightly stifled 4 into 1 all the rest std.
Now has cams, full race pipe but no dyno sheet yet
Make sure your electrics are Ok, timing (valves and ignition), valve clearances all carbs set the same - then get it carbon analysed.
