Day light MOT's
531johns
Day light MOT's
#1 PostAuthor: 531johns » Tue Mar 16, 2010 7:54 pm
Right chaps heres one for you all. What is a day light MOT and what do you have to do to a standard bike, with lights that dont work very well, to get it through a day light MOT.
all answers gratefully recieved :shock:
Z1000J, ZZR1400, RD400F, BMWM5.
Fully Paid up member,
uk kev
#2 PostAuthor: uk kev » Tue Mar 16, 2010 8:08 pm
A daylight MoT is for a bike with no lights, so you can't have any on the bike, so if you don't have any lights, you can't have the swithches either, as any switch or light fitted to the bike when MoT'ed must be in working order.
uk kev
#3 PostAuthor: uk kev » Tue Mar 16, 2010 8:13 pm
just found this on a quick google search...
Just been down to a local MOT Station and asked the bloke outright. The basic answer is that there is no official daylight MOT. You present your bike for a normal MOT, it then either pass's or fails. In the case of headlights, mirrors, brake lights if they are fitted then they must work, you will not get away with them being masked over. You do however require a horn, this does not have to be run from the engine electrics.
If your bike has no lights etc and pass's you will be given your V30 certificate, but also a V32 which states that the bike had no lights etc at the time of tesing, and should only be used during daylight hours (sound familiar) and not at night or during times of low visibility. This will also advise you to get lights etc.
Lots more info out there in web land..
london calling
#4 PostAuthor: london calling » Tue Mar 16, 2010 9:13 pm
I think if the light switch is taped over so that it is in-operative then that is okay.
This means you could keep your switchgear to operate the horn.
You also need to have a speedo fitted.
Jack
floydsz1
#5 PostAuthor: floydsz1 » Tue Mar 16, 2010 11:14 pm
My mot mate says that if the switch is part off the throttle assembly or clutch lever/brake assembly then its ok.
I also thought you had to have a speedo but i belive its not part of the mot as they have no way off checking if its working. A local guy is selling a suzuki drz400 enduro on ebay. he states that it does not have a speedo because this is how it comes from suzuki but it is fully road legal.
i find it hard to belive that you dont even need a brake light. basicaly if lights are fitted they must work but if you take them all off, inc indicators then you dont need them.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
Redbeard
#6 PostAuthor: Redbeard » Wed Mar 17, 2010 8:06 pm
From what i can find out, as long as the bike has a minimum of;
Working horn (continuous electric, no clown hooters).
Working rear brake light.
Full size number plate.
Reflector...
...then it will pass the mot (daylight only). The certificate will be stamped 'daylight use only'. Some will pass it with just the brake light, but it seems to be down to the individual testing it. If you keep lights fitted then taping them up is apparantly good enough. Best to speak to your tester beforehand as its the only guarantee of what they will accept. Its too hit and miss.
1979 Z1000ST
Robw
#7 PostAuthor: Robw » Wed Mar 17, 2010 8:42 pm
My Z has a daylight MOT all it needed was an electric horn and a reflector, it does not need a rear brake light. However if it has a dual seat it has to have footpegs fitted at the time of the MOT.
Rob
london calling
#8 PostAuthor: london calling » Wed Mar 17, 2010 9:10 pm
Nice one Rob,I forgot all about the reflector.
If a single reflector is fitted it should be in the centre line of the bike.
Jack
Users browsing this forum: moizeau and 81 guests
