Thanks guys
Russ
Thanks guys
#1 PostAuthor: Russ » Sun Apr 22, 2007 2:41 pm
Just want to say thanks to everyone for there help. Stripped her back down again and used my own patent glazebreaker to hone the bores Image and then this Image She's all back together again now and I've just taken it up the road for the first time since september and although a little smokey no more than I would expect and I expect this to reduce as the rings wear in. So thanks again all for the help. Catch you sometime out there......
MaineKZ
#2 PostAuthor: MaineKZ » Sun Apr 22, 2007 6:34 pm
Blimey Russ - that looks like something you'd hire to sand your floors :shock:
Still if it does the job then more power to ya :D
#3 PostAuthor: Pigford » Sun Apr 22, 2007 6:38 pm
Looking at the meat on those liners, I'd have gone for at least 3mm, up the capacity a bit :wink:
Thats what its all about, 'suck & see', can't beat a bit of DIY home mechanics :!:
kiwiz
#4 PostAuthor: kiwiz » Mon Apr 23, 2007 7:33 pm
Talking about " meat in those liners " what is the practical limit on liner wall thickness?
Success is the ability to go from one failure to another without loss of enthusiasm
Jeff Saunders
#5 PostAuthor: Jeff Saunders » Mon Apr 23, 2007 8:51 pm
Kiwiz, you'll get different answers from different people. I tend to err on the safe side. So with a set of 900 cylinders (66mm stock), 1015cc (70mm) is the most I'll go personally - there are people who say 104cc (71mm) is the max, but that leaves a very thin wall.
Similar with the 1015cc cylinders, I'll only ever go 1075cc (72mm), although I know people running 1105cc (73mm). With both the 1045cc and 1105cc bores for 900 & 1000 respectively, I do know several people who distorted the sleeves - not something worth risking for a small number more cc's.
