Oil Capacity on KZ1000
Jim Goose
#1 PostAuthor: Jim Goose » Thu Jun 16, 2011 7:25 am
Hi Guys.
I Drained the oil and replaced the Oil filter yersterday.
When I filled the engine with oil, it only took around 1.5 Ltrs before it registered full on the display window.
The filler cap has 3700CC (3.7 Ltrs) stamped on it.
Any one else encounter this, or know if I have enough oil in it?
Rob
Mark Tiller
#2 PostAuthor: Mark Tiller » Thu Jun 16, 2011 8:59 am
did you drain it via the sump plug(Big bolt)or just the oil filter drain screw and change filter?
how much came out?
did u drain it warm?
its deffinitely 3.7l though
07962421462
KeithZ1R
#3 PostAuthor: KeithZ1R » Thu Jun 16, 2011 11:24 am
Might sound obvious but I would take the clutch cover off and clean the indicator window :) 1 and a half ltrs aint nowhere near enough :shock:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
garyd
#4 PostAuthor: garyd » Thu Jun 16, 2011 1:03 pm
Also it takes time for the oil to seep into the filter. have a look again today to see what it says
Jim Goose
#5 PostAuthor: Jim Goose » Thu Jun 16, 2011 2:11 pm
Thanks for the tips lads.
Defo something a drift.
I'll drain the oil again tonight, use a few methods and see what happens.
:D
PaulMceleney
Chunks
#6 PostAuthor: PaulMceleney » Thu Jun 16, 2011 6:40 pm
Also worth taking the sump off and remove the oil pump and give it a clean its a easy job and well worth doing you will be surprised how much crap is stuck to the oil pump
Jim Goose
#7 PostAuthor: Jim Goose » Fri Jun 17, 2011 8:15 am
paulmceleney wrote:Also worth taking the sump off and remove the oil pump and give it a clean its a easy job and well worth doing you will be surprised how much crap is stuck to the oil pump
Might do that if it,s not too much hassle. Do I need to remove the header pipes? Will I need a new sump gasket?
Drained the oil from the larger of the two bolts, and got the full 3.7 lts out. Happy Days.
Mark Tiller
#8 PostAuthor: Mark Tiller » Fri Jun 17, 2011 10:23 am
If you do the sump you will need to remove the headers and get a new gasket as you dont want to have to do it twice.
when u drain oil again... u do both large and small bolt, and i would always do filter at the same time
07962421462
HowieD
#9 PostAuthor: HowieD » Tue Jun 21, 2011 10:43 am
I've always found that after changing the oil & filter: topping up with 4 litres of oil leaves it at full after running the engine.
The filter keeps hold of the extra 0.3ltr
hope that helps.
regards
H
