Now 2 & 3 not firing
kwaka
#1 PostAuthor: kwaka » Wed Jun 22, 2011 10:54 am
I took Pauls advice and tried to swap leads 1&4 because 4 wasn,t firing, but the leads are too short. So after replacing them, i started the bike and both 2&3 arn't firing, Does anyone have any idea? :??
69chris
#2 PostAuthor: 69chris » Wed Jun 22, 2011 11:07 am
i has similar problems with my 11R yesterday, one minute it had no spark at all, then it'd fire on 1/4, then on all 4, then only on 2/3......
it was the connector plug from the ign pick ups, it all looked ok but once i pulled it apart i could see it was full of horrid green corrosion !!!!
double check all connectors 1st, it could be something nice and simple :)
#3 PostAuthor: PAULJAC47 » Wed Jun 22, 2011 5:39 pm
Swap the coils over and see what happens,did you fit new ht leads or use the originals?
kwaka
#4 PostAuthor: kwaka » Sun Jun 26, 2011 2:48 am
G'day fellas, now i'm not even able to get the bike to fire up at all. The connectors seem ok. I've checked the primary windings and geat a reading of 4 ohm, but the secondary windings give me no reading at all, are my coils cactus?
#5 PostAuthor: Pigford » Sun Jun 26, 2011 8:09 am
If 1 & 4 weren't working - then you swapped the leads with 2 & 3, and they stopped working - its gotta be coils (or slim chance of 2 x duff leads/caps) :!:
kwaka
#6 PostAuthor: kwaka » Sun Jun 26, 2011 8:19 am
Managed to get it going, sprayed every connector i could find and threw in another set of plugs :D . Someone mentioned putting HT leads on, is it possible to replace the leads only?
Users browsing this forum: zapo and 69 guests
