My side stands been rattling a while so had a look this morning. The bolt which holds it on is stripped so cant get any decent tension on it. Any body got a spare? or its off to Z Power
Is the bracket on the frame it screws into/through meant to be threaded on the rear 'flange' or is it just retained with the nut?
Side stand bolt
- bigalhudson
- Regular Poster
bolt
Its threaded plus the nut
- bigalhudson
- Regular Poster
Hi Al,
no need to heat and bend the side stand mounts - I had this problem on mine.
Fixed it by sticking a stainless washer under the bolt head - machined down so you can't see it sticking out. This allows the bolt to close up the stand mount slightly when it's tightened. Otherwise the shoulder stops it doing this. Try it - it works honest. From Mark.
If I can find a spare bolt i'll pm you.
Users browsing this forum: Bing [Bot] and 18 guests
