fitting an oil cooler
lomi
#1 PostAuthor: lomi » Tue Jul 05, 2011 3:12 pm
I intend to fit an oil cooler to my Z1000 J3 where is the best place to take the oil feed from? Also other than a cooler and lines i presume i would need some kind of take off from wherever the oil feed will come from? Are these available to buy or is it something i would need made? Also what size cooler should i be looking for? Sorry for loads of questions but this is a modification i have no experience with at all.
cheers
Taffus
#2 PostAuthor: Taffus » Tue Jul 05, 2011 3:24 pm
lomi
#3 PostAuthor: lomi » Tue Jul 05, 2011 3:37 pm
thanks for that, without sounding too thick where does that go :oops: ?
mattc
#4 PostAuthor: mattc » Tue Jul 05, 2011 3:58 pm
The oil pipe block just goes in place of the standard Z1000J oil pressure switch on the uppper crankcase behind #3 cylinder. The touble with using the block off a Unitrack (GPz1100 A1/2) is that you loose the capability for the oil pressure switch as that is fitted under the oil pump (below crankcases) on these models. You shoud get the block/pipes/cooler from a GPz1100 B1/B2 as these have the switch still mounted on top of the block with the oil flow/return pipe mountings on it. Oil pipes route over the head and down to the cooler although there are options usng customs pipes to route it other ways. I have this on my Z1000 J2 and works just fine. Cheers Matt
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1170B1 x 2
mattc
#5 PostAuthor: mattc » Tue Jul 05, 2011 4:45 pm
Just thought...if you want a piic then pm me your email and I can scan the pic from the w/s manual that shows it clearly and send you a pdf. Matt
Matt C
#6 PostAuthor: Pigford » Tue Jul 05, 2011 4:51 pm
I've got an oil cooler take-off unit for sale :wink:
Robw
#7 PostAuthor: Robw » Tue Jul 05, 2011 6:07 pm
Alan Cooper at Kipkawa sells them with an oil cooler sensor adapter. Check out his website.
Rob
lomi
#8 PostAuthor: lomi » Tue Jul 05, 2011 6:11 pm
mattc wrote:Just thought...if you want a piic then pm me your email and I can scan the pic from the w/s manual that shows it clearly and send you a pdf. Matt
Matt thanks mate, i'll pm you my e-mail addy :D
lomi
#9 PostAuthor: lomi » Tue Jul 05, 2011 6:12 pm
Pigford wrote:I've got an oil cooler take-off unit for sale :wink:
Hope its cheap :D :D :wink:
#10 PostAuthor: paul doran » Tue Jul 05, 2011 6:18 pm
it will be as cheap as chips from Piglet dont worry :lol: :lol:
mattc
#11 PostAuthor: mattc » Tue Jul 05, 2011 6:35 pm
pdf pic sent Lomi.......
Matt C
lomi
#12 PostAuthor: lomi » Tue Jul 05, 2011 6:55 pm
mattc wrote:pdf pic sent Lomi.......
Thanks mate :D
