z1000 clock bolts
slappa13
z1000 clock bolts
#1 PostAuthor: slappa13 » Wed Jul 06, 2011 6:32 pm
Hi Guys
Do the studs that hold clocks to yokes come out of clock mount, as one of mine is bent. thanks Neil
DDZ900
clock bracket
#2 PostAuthor: DDZ900 » Wed Jul 06, 2011 7:14 pm
frade not ! i have a clock bracket if you need one !
zseries Rob
clocks
#3 PostAuthor: zseries Rob » Thu Jul 07, 2011 8:11 am
If you took the gauge apart the stud can be removed and a new one spot welded in, I have done it where the stud was broken off.
Rob.
DDZ900
clock bkt
#4 PostAuthor: DDZ900 » Thu Jul 07, 2011 6:29 pm
arrr i thought you meant the alloy clocks bkt that bolts to the top yoke through rubbers! :oops:
slappa13
#5 PostAuthor: slappa13 » Thu Jul 07, 2011 6:48 pm
Yes i ment clock bkt that bolts through top yoke in rubbers
DDZ900
clocks stud
#6 PostAuthor: DDZ900 » Fri Jul 08, 2011 6:31 am
ar well i stand my post ! :wink:
#7 PostAuthor: Rich » Fri Jul 08, 2011 3:59 pm
Cut it off flush with the bracket, drill, tap and then make a stud up the right size to fit and locktite it in.
Alternatively put the bracket in some water so the stud sticks out, heat the stud and bend it straight.
Personally I would take DDZ900 up on his offer.
