650 o ring question
Crofty
650 o ring question
#1 PostAuthor: Crofty » Fri Jul 22, 2011 8:32 pm
I have a few 650 motors in bits. Some of them had/have 2 rubber o rings that are on the rh two inner cylinder studs. They are slid right down to the bottom of the stud, flush with the gasket surface of the top of the crankcase where the barrels seal.
My factory workshop manual does not mention them and none of the vesrah gasket kits I have used before on my running engine (which did not have them) have them in the kit.
Anyone ever encountered them and how do you know if you need them?
zedrider
#2 PostAuthor: zedrider » Sat Jul 23, 2011 12:21 am
yes ive seen them before . not sure of why they are there . the kits ive had a long time ago had them .included . so i used them
zed
