Generator rotor tool
tlc
#1 PostAuthor: tlc » Wed Aug 03, 2011 6:27 am
Does anyone have the generator rotor tool to suit my 1000 A that I could borrow please?
KeithZ1R
#2 PostAuthor: KeithZ1R » Wed Aug 03, 2011 7:41 pm
Ever the resourceful type I made a slide Hammer out of the swing arm spindle however screwing it in tight and LIGHTLY taping with a hammer whilst pulling will remove it . Make sure the bike is facing North/South :wink:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Taffus
#3 PostAuthor: Taffus » Wed Aug 03, 2011 7:59 pm
KeithZ1R wrote:Ever the resourceful type I made a slide Hammer out of the swing arm spindle however screwing it in tight and LIGHTLY taping with a hammer whilst pulling will remove it . Make sure the bike is facing North/South :wink:
dont forget to remove the battery earth too! or this could happen :shock:
PaulMceleney
Chunks
#4 PostAuthor: PaulMceleney » Wed Aug 03, 2011 8:16 pm
front wheel spindle fits, also the bolt that holds the top yoke down will fit, hold the rotor with a chain and rachet that used to remove oil filters from cars can be done in minutes this way just keep tightening the bolt and it will pop off if you can borrow mine if you do not have the tools to this job or i can come over to your house
#5 PostAuthor: Pigford » Wed Aug 03, 2011 8:21 pm
I use a nylon tie-down strap to hold rotor so it don't get damaged :wink:
PaulMceleney
Chunks
#6 PostAuthor: PaulMceleney » Wed Aug 03, 2011 8:25 pm
I use a rag underneath the chain so there :lol:
#7 PostAuthor: Pigford » Wed Aug 03, 2011 8:28 pm
I used an old duvet (13 tog) under the "soft & gentle" nylon straps :twisted:
KeithZ1R
#8 PostAuthor: KeithZ1R » Wed Aug 03, 2011 8:32 pm
Boys Boys :!: if you wait long enough the feckin thing falls of anyway :D :D :D :D
Keith
:bop :gom
mistaken.
tlc
#9 PostAuthor: tlc » Thu Aug 04, 2011 4:17 am
Thanks for the replies fellas but getting it off should be no prob. (I hope)
It`s the tightening up job I need the holder for.
Thankfully the club have one :D
KeithZ1R
#10 PostAuthor: KeithZ1R » Thu Aug 04, 2011 7:14 am
Classic case of not reading request properly :oops: and yep Ive got one Chris
Keith
:bop :gom
mistaken.
Hobbo
International Rep
yo
#11 PostAuthor: Hobbo » Thu Aug 04, 2011 7:19 am
Chris
Me too
Phil
International Rep
#12 PostAuthor: Rich » Thu Aug 04, 2011 3:04 pm
sprag the starter clutch intermediate gear with a piece of aluminium comes to mind, I think that's what I did on the Mk2 engine and it's 110 ft lbs ish :shock: Then I made a proper tool for it :D
KeithZ1R
#13 PostAuthor: KeithZ1R » Thu Aug 04, 2011 5:28 pm
or you could wrap some thin ally sheet around it and grab it wiv 24 inch stilsons :shock:
Keith
:bop :gom
mistaken.
Users browsing this forum: No registered users and 76 guests
